More voltage will not help the majority of these chips.....they like low voltage...Honestly I really don't have time to try getting 4 gig stable ( I did it on the ddr II 790FX board ).....I'm very busy and working on other stuff currently.......like specifically ram clocking which is currently horrible with the 955's on this board......
I have stated memory is the KEY to Ocing PHenom II's so this most likely is the source of your issue anyway..........try doing this instead.......And don't use 1600 divider for now.........if you can't get your RAM/NB(IMC) to pass prime blend you will never get the cpu to 4 gig.........You really really need to seperate everything into categories.........then try to mix them together.......Try finding voltage necessary to pass prime with higher NB frequncy with ram and cpu underclocked.........then try with ram clocked.............then turn those down and find voltage needed for a cpu clock only...........then put it all together............
Little tip......errors at 8K, 10K and so on are cpu errors........errors 1024K 768K and such are memory controller/memory related.........
Example memory and NB ( internal memory controller ) clocks combined........These are the new low voltage OCZ animals I'm using here.....1.65v :cool: Death to high volt ram kits................
http://members.cox.net/hoobahans/amimals3.JPG
