What are you using for Air??
TT big typhoon with 120 delta fan....http://www.xtremesystems.org/forums/...&postcount=296
wow you guys keeping 24/7 or just suicide run?
Little Vapo run before I may sell her...
http://img66.imageshack.us/img66/456/superpiki7.th.jpg
Got my Deneb today:cool:
Not installing yet, I got to get my act together and still prepare the motherboard:shakes:
Anyway, stepping is 0849EPAW.
Must be a good stepping. Mine is 0849DPAW and 6GHz was a piece of cake...:D
I dont want to be greedy, 4Ghz on air is enough:ROTF:
Nah, I hope I get some good clocks from it, but I mainly hope everything just works fine now, so HTT of 300 and RAM at DDR1200, Hopefully running stable at 3.9Ghz and the NB at 2.4Ghz or so:rolleyes: But, time will tell:rolleyes:
[img=http://img99.imageshack.us/img99/7923/phenomiix49403675ghzstain5.th.jpg]
There's a stable setting. Updated list is about to get uploaded. I'm down at school now so I'm just going to waste all my time on updating this thread and making mine run faster:D.
3.675 cpu with 1.425v and phase cooling obviously
2.45 nb
980mhz ram @ 2.1v
1960 ht link
Windows Vista x86
I can't seem to get mine to even take a SS at 4GHz. Damn you, Thermal Monster! I can tell this chip is all about the temps. Adding voltage markedly increases stability until temps get too high--then it crashes. It's kind of like how the older chips used to behave years and years ago before we hit that period where voltage only mattered to a small extent.
First test run (barebones) mine did okay with AMD HSF - results so far:
Stock vcore = 16x200 = 3200
Added 0.1v = 17.5x200 = 3500
Well I have a dead stick of RAM (Corsair Dominator PC2-1066) so RMA today - have to wait for replacement........
I did just barely :D
http://www.jonspd.com/jonspd_uploads/screenies/4.JPG
Anyone Overclock yet on Windows 7 ? Soon here just installed....
http://img502.imageshack.us/img502/3586/windows7gb5.png
I'll be installing Windows 7 on it later today, right now its priming at 15x255=3825 @ 1.475v set, 2550 on the nb, and 1785 ht link. Don't have time to install it now since I have class in 15 minutes:(. But I will be getting 4+ghz stable by the end of this week no matter what, otherwise this phase unit is absolutely worthless.
Edit: I would recommend setting your own timings as sometimes it screws them up royally. I always go to the 800mhz divider and do 5-5-5-15-26 at 2t, and if anyone knows how to do a higher trc on my board in the bios it would be much appreciated.
so old guy you really want this darn stepping ?
280 is here :D
Windows 7 Beta ATI drivers: AOD not working this Windows 7
http://support.ati.com/ics/support/d...estionID=39069
Overclock results seem a bit more stable in windows 7. Occt seems to work fine. One of my overclocks would constantly fail at around 15-17min mark with occt in vista 64 SP2 and windows 7 could get to 23-25mins.
Other than that, starts up a bit faster and seems really snappy.
PS: ati beta w7 drivers are given me low fps in l4d vs mode but not single player ??!?!
I'm going to start the install in about 20 minutes, need to wait for my 2 hours of prime to finish. I really wish my network plug hadn't died at the wall, cause now I actually need a wireless card until I get it fixed.
By the way, has anyone noticed a newer version of aod than 2.1.5 yet?
