it tells me there is not enough memory when i try to select the max memory test, weird.
I can second XP x64... it is a great OS. I am only using Vista x64 because I have 4 GPUs :(
AgentGOD
Would u like to make the new interface and design for 1.5.1 ? :) I love 1.5.1 ;)
Thanks agent will make a donation tonight when i get home
http://i243.photobucket.com/albums/f...apudding-1.jpg
Regardless, if I could do the same test in HCI and have it produce errors FASTER than this tool, why would I use this tool to begin with is my point.
I want a tool that produces errors the fastest. And for memory, this doesn't do it.
HCI - 1024MB errors out FASTER than this tool with 10 passes at 1500MB.
So like I said, its possible that this tool can detected CPU errors FASTER than Prime or SuperPI, but for RAM errors it needs MORE TIME.
I want a FLOPs printout like the old version had.
Any ideas why I would be stable with BurnTest and get errors within seconds with Prime95? I am stable using both at default 3.2 GHz but get errors at 3.4 GHz with Prime95 even though BurnTest remains stable.
AgentGOD, do u see my message above?
I am running 64 bit Vista. I have not run 20 iterations at one time but have run 10 iterations multiple times after minor changes and have been stable with BurnTest but still run into early error (less than 15 seconds) with Prime95 with only a minor overclock (3.2 GHz to 3.4 GHz). I had thought Burntest would find instability faster then other stress testing programs. Is this a 64-bit Vista issue? Any other thoughts?
Do you have voltage variations running IntelBurnTest vs running Prime95? (Talking about CPU voltage at load)
If so, that would be what I'd look into, especially with Load-Line Calibration on. It seems that some boards give the CPU different voltages during different loads. I have not tested Vista 64-bit on this PC, so I couldn't tell you if that's the reason. I've only tested XP x64 Edition SP2 (so I can't tell you how effective it is on Vista 64-bit), and from my experience, it's much much faster than Prime95. My original 10hr Prime95 stable CPU clock failed IntelBurnTest within 2 minutes. For that test, I used the 64-bit version of Prime95.
Yeah, I saw your message about slapping a full Windows GUI on it vs console, but I decided to stick with the original style.
"Weird events" can be caused by system instability as well. I learned my lesson with my AMD Opteron... it wasn't fully stable, and my Windows installations all eventually got screwy like yours (both XP and Vista [I had both installed in a dual-boot configuration, using 32-bit]).
Keep this in mind: neither IntelBurnTest nor Intel(R) LINPACK sets anything to start on Windows startup, nor start stress testing without the user's consent.
Can you pass Memtest86+ for a few hours?
run this: http://hcidesign.com/memtest/
use two instances, at 1024MB each (if you have more than 3GB of RAM), and do at least 300% coverage.
Voltages are exactly the same when running BurnTest and Prime95. I'm still at a loss with this one. Perhaps it is a Vista issue?
Thanks for the info on SuperPi vs HyperPi. I found that I was 3D unstable and SuperPi unstable until I adjusted clock skews. I am currently at a delay of 250ps for both channels. I am now SuperPi and 3D stable with 4GB memory at 1600 MHz.
