my girl, and yea i know but she bought the red one so i had to put it in. Doen't look to bad IMHO :-p
hiya.
the case isn't my style but it looks like Lian-Li in a way.
thermaltake bigwater I see what is quite good I think.
and nice pc setup.
xyus
tht case is such a rip off of the CM stacker lol
but ya made it look pretty :p: really good job ya did there Jbreaks
thanks :) is a nice cheap way of looking ok
awesome rig other than the case :D
can we see a picture of your 32 inch monitor?
Yeh nice case man props. Hey JBREAKS what kind of UV CCFL do you have in there.
I love UV Green, you should invest some green uv ides the yellow dfi ones seem outta place
are you asking what uv light or what coolant im useing?
lol whyd you change your avatar.....your new one is weird....:p: i like elisha cuthbert better lol
here's mine
http://img103.imageshack.us/img103/1...00561ja.th.jpghttp://img103.imageshack.us/img103/5...00572gj.th.jpghttp://img115.imageshack.us/img115/5...00770qe.th.jpghttp://img115.imageshack.us/img115/4...00785dw.th.jpghttp://img103.imageshack.us/img103/3...00683df.th.jpg
http://img248.imageshack.us/img248/4...00891xu.th.jpghttp://img158.imageshack.us/img158/1...00824um.th.jpg
took your advise and tried the green look
heres my pc
specs
3.0c @ 3.8
ic7-max3
ocz rev 2 r1.1 : (
evga 6800nu
vantec 460 watt psu 30 amps on 12v
I still love that case... wish I haven't sold it to my friend at times... Best airflow for 80mm fan cases I've had and sturdly built to boot for aluminum case. Only hard thing was... shoving HDD in and out with location of those connectors on IC7 :PQuote:
Originally Posted by calcal
yeah its an awesome case
imo i think these case have the best interiors =]
just look at my wm :D
What case is that? :)
coolermaster ATC series, or Coolermaster ne pretorian,or other dno
its coolermasters ;)
coolermaster praetorian black
looks nice huh =]
very nice wire management calcal
hiya,
My case is A TOTAL mess probally the worst of XS.
can someone tell me how to hide all your cables? or give me a good tutorial?
xyus
use zip ties or sleeve them.
Pm me and I can hook u up with some good pics.
Originally Posted by IYP
cool thanks!
hi,
@CalCal: You putten your kabels behind your motherbord or not?
found a good guide and will do the same with my new case :)
What you guys think about the thermaltake Soprano?
http://www.thermaltake.com/xaserCase...no/bws/bws.htm
seems quite good to me and what is the difference between the Tsunami dream? :confused:
Xyus
It looks same as wavemaster except
its made with SECC, not aluminum.
I tell you, that case is SMALL.
If you have load of equipment they will tightly fit or not fit.
Not that many TT cases are fully aluminum.
I suggest you go with lian li for light weight/ space.
If you hate the design.. you can always mod it :D
um ill take a picture for you guys how i hide my wires, gimme 30 minutesQuote:
Originally Posted by Xyus89
dont get thermaltake, their an evil company ( and they make ugly cases)
alright than :)
the main prob with my crap case is SPACE and it was 60 euro's with 400w powersupply so..
So can you recommend me a nice spacious case without plastic crap on it? without power supply (I hate that with antec, always powersuplly with it!)
Xyus
(koolance, I'm gonna send you a pic of my wiring and hopefully you can put it online)
What is the difference between a SECC case and a Alu case?
http://www.antec.com/ec/productDetails.php?ProdID=01001
seems quite spacious and cheep.
