Indeed... I couldn't believe that at first, but now someone else also confirms the same thing. But yeah... one PCI-E slot is truly... inconvenient.
I am going to revert this back to Maximus instead of Rampage and see if it gets any better:confused:
If not I will probably wait for P45 or buy a Rampage or DFI X48...
And... I'm uploading a video on YouTube. :)
P.S.: And creating a separate thread for ASUS P5E-VM HDMI in a few minutes. I think the board finally deserves some attention. ;)
BUMP! No thread yet... since I don't have enough information to post. But I have a video for you all. :)
http://www.youtube.com/watch?v=kZSocwaQntA
^= And THAT's the power of mATX! :up:
A guy from Gathering of Tweakers (A dutch forum) called to Asus and he talked to the BIOS Department fron Asus. He explained the problem to Asus and the will look what the problem is and he'll fix it! Next week we hear more from Asus and what we can do to fix the FSB limit on the X48/X38/P35 motherboards. Maybe they will come with a new bios with the fix in it.
Great support from Asus!
:up:
I agree, this is most likely an issue with f***kin' X38 implementation - why the hell did it take so long to ship this board if they did not test it with then-available 45nm samples (they were out)? More importantly what's up with newer BIOS releases and when can we expect something that makes these board useful?
Apparently current ASUS X38 boards are USELESS for *ANY* 45nm QUAD CPU OC, period. UPDATE: it seems they will act fast which is good. :cool:
Man, I'm so pissed...
Just as I thought after the extensive trial and error (mostly error) that I did trying to get this damn chip to clock worth a damn.
If Asus pulls this one off, its just 1 more reason for me to continue to buy Asus products :)
And... update. :) I find the CPU score significantly lower than 3.90GHz on the X3350 for some reason.
http://i235.photobucket.com/albums/e...06CPUScore.jpg
Edit: No GPU score yet... unless you want me to bench the onboard X3500 GPU?
Yep... definitely lower than X3350. Then again, I haven't... changed any GPU settings yet. Maybe the onboard GPU is limiting me. :D
http://i235.photobucket.com/albums/e...PUScore490.jpg
Hi , is it worth me getting a X3350 chip to replace my 6600 go at the moment then or should i wait for better bios or a better board , got the maximus with rampage bios mod at the moment steady at 3.8 gig
@RunawayPrisoner, I dont think its the onboard GPU cuz I get around the same score @3.2GHz in 2D, 3D, Overclocked, Underclocked
51XX-52XX range even Underclocked got 5220 :shrug: 300-300 on the Gpu
http://www.picgarage.net/images/score_67919_453.jpeg
So far this is the best I've been able to get on air with decent temps. I doubt it is prime95 stable but It did get 20 minutes into OCCT before I got bored and closed it.
Oh really???
http://i235.photobucket.com/albums/e...oretweaked.jpg
http://i235.photobucket.com/albums/e...reTweaked2.jpg
Slapped a brand new 9600GT that I ordered for some customers in there... and voila. :p: Anyway, card is back in box and I won't be benching that thing at all.
P5E-VM HDMI really needs to be droop modded. I set 1.525 V bios, and the droop bounces between 1.336 V and 1.344 load.
http://individual.utoronto.ca/bzhou/...mhdmi-3800.jpg
Well, you're lucky, at least. I need 1.36-1.38v for my Q9450 to be stable. Seems like the Xeon chips can clock higher at lower voltages.
But anyway, nice clocks!
@zoob
whats the NB volts set at?
is it still going or you stoped it ?
Still going! I dunno what happened but the vCore went up by itself! I'm not sure what NB is set at, I just kind of threw some voltages at it, bumped up vcore and clock overcharge and hoped for the best. Once I reboot I'll take a look.
http://individual.utoronto.ca/bzhou/...dmi-3800-2.jpg
your on water right ?
so now I have some one to compare temps to :D
edit: scythe ninja I guess thats a no :(
