RealTemp 2.11:
Maybe I should call this the GraySky edition!
For GraySky and anyone else that can't accept the TjMax I have chosen for their processor or even for users that just want to make some comparisons to my CoreTemp competition, then this is the version for you.
I've added a file to the distribution called RealTemp.ini
It's a simple text file that contains the following info but really only needs to contain a single character: 1, 2 or 3. By setting it to one of the following values here's what you can do:
0
TjMax adjustment feature
0 NO adjustment
1 + 5C adjustment
2 +10C adjustment
3 +15C adjustment
If you don't need this feature then you can delete the RealTemp.ini file or you can continue using version 2.1 which is exactly the same as this version except for this one feature.
This is a temporary beta version and the structure of the .ini file will likely change in the near future to accommodate additional features.
http://www.fileden.com/files/2008/3/...7/RealTemp.zip
