Ive got a Q77A761 E8400 and doesnt seem to be as good as lots on here,i think uk has got runt of the litter in terms of good batches.
i need nearly 1.4v (cpuz) just to get it stable at 4050.
Here you go -> http://www.xtremesystems.org/forums/...d.php?t=174547
Same batch :)
I hope you can get it stable at 4.5 for daily use if that's what you mean. From my testing i've noticed that this CPU batch really likes vcore. I can get it stable at 4.3 with 1.5v set in bios (1.48v real) and that's the max i want to use for air cooling. Mine needed around 1.55v or so real to get 4.5 stable and i think it's too high for daily use. Anyway, hope yours is better and your cooling is more efficient then mine. :)
Can whoever took the liberty of making this 'official' thread start documenting everything in the original post?
BTW, by stable i mean OCCT stable. I can setfsb my way to 4600 and do a quick superpi even at 1.4v :)
gaiz - Here's a little comparison I threw into a graphic from the intel spec sheets for e6000 and e8000 series -
http://www.movement-radio.com/intelspec.jpg
Now don't kill the messenger, but I wanted to save anyone who cares about intel specs the time of opening and scrolling two pdfs.
The max Tc for e6000 series is 60.1c for e8000 series it's 72.4c
So what does anyone think about max volts? I've read about two failures so far - one at 1.4v and another at unknown volts but it came back mysteriously. II'd really like to know how far we can push these suckers for 24/7.
mrcape thanks for the post dude :up:
dodgy name tho ;)
just had my psu blow up so im not going to be able to test :down:
Ouch
Is it usual for one core to have a 4-5c difference in temp under load? I tried re-seating the EK block a few times, but it's always the same.
I also have the idle bug, one core never goes below 42c, the same one that has higher load temps.....
Anyone have a stable 4500 and care to share there volts, ect?
After prime finnishes with my 4300 setup, I plan/hope to get a 4500 24/7 setting stable
Come on push these CPU's, feed them voltage!!!! But really, It takes a real Idiot to fry your CPU that way, It's a risk who's positives outweigh the negatives, IMO. These chips run way cooler so thats another thing you've got on your side.
I am worried about the temperature more than vcore, my load temp at 1.4v with watercooling is 70 degree C...
Hey Grnfinger,
No 4.5 stable but I have been there with 1.44vcore to creep around. I'm doing same as you now, finally Prime and Occt stable at 4.2ghz vcore = 1.43 - High!! But I have yet to back it off or fine tune.
What about a table or a template with voltages etc., so we can all compare results?
There's a thread doing just that at ocxtreme which might interest you -
http://www.ocxtreme.org/forumenus/showthread.php?t=2453
What are your voltages for 4.3 stable? What stability test method did you use?
here is my at 4.2GHz 1.368v
http://img508.imageshack.us/img508/5112/orthos2ny8.jpg
It's bizarre how these chips differ so much with volts and temps. Icywater that's great 5 hours small fft. It's getting hot man! But I'm like you, more concerned with voltage on this chip.
Can I ask what is your FPO / Board / NBvolts / Pll ?
:ROTF: :clap: Got This today http://valid.x86-secret.com/show_oc.php?id=303613
:eek: running with windows 2003 server and no mods.
coretemp 0.96.1 and everest
