Originally Posted by
KTE
Yep, it can increase oc/stability. Just have a high MaxAsyncLatency value and you should be good. If drive strength is incorrect, the system should tell you at bootup when it performs the calculations.
Also, for anyone running P95 and having it stable and later getting freezes/lockups do this: open up AOD, monitor every core. keep your eye on it and what the cores are fluctuating to. I bet if it was 100% stable and you're sure of this but you start getting freezes, there must be PLL movement, i.e. 2.6G set must be shooting up past 2.7G for a quick second and causing lockups. ;)
Just keep an eye on your cores for a while to see if there's any large fluctuation; it'll occur at idle, not under load.
