awesome, didn't think about that one! Thanks!
btw love that quote "Friends don't let Friends use ThermalTake" :rofl:
Oooh, it looks awesome in the pictures, now let's hope it performs as well as it looks!
Is it only me who thinks the slightly offset barbs make it look a bit errr silly
Hey eddy, just would like to extend thanks/gratitude from australia for continuing to produce such high quality blocks :)
Small question however, my 8800GTX-FC copper is slightly tarnished, and its delrin on the inside, any tips for cleaning/polishing it?
Thanks for the pics, guys. Glad you got your blocks!
Is that the HiFlo nozzle-plate?
http://img259.imageshack.us/img259/2434/1000373wy8.jpg
Thnx for the pics :up:
I'm ordering one tonight.
When its in ill try to sell my 1 month old fuzion, as long as I get 50€ for it I'm happy. :D
I just really don't want to bow my Fuzion myself, I always mess those lil things up.
Hopefully my temps won't be ruined by my upcoming HD3870 with my upcoming MCW60. :clap:
I can barely wait for the test results!
a cant wait to see the tight one and its performance ... cheers :up:
anyway, how will it be selled? for example, I saw it listed at one shop here @ cz, and its called EK Supreme Acetal .. What do I get except for the block (which I mean - base, mounting plate and top) thx
Okay for what it's worth a quick test.
A few things to bare in mind about my setup.
1. Ambient around 24-26c(Guessing here. Aircon is set to 24c, but it's a large room). In other words pretty warm.
2. Sides off case and fans on full.
3. Overclocked 8800 GTX volt modded @ 1.47v in the loop
4. The supreme is just installed, so thermal paste(MX-2) hasn't really had much time to settle in. Not sure how much difference that will make though.
5. Both the supreme and apogee GTX tests are hard mounted with a back plate.
6. Rads etc could probably do with a proper clean out. A bit lazy on that one.
7. bare in mind I'm no expert.
Lastly a nice little discovery for me. Red UV dye is in fact a pretty Barby pink:brick:
Okay then. Only 10 minute runs.
Apogee GTX Q6600 GO 422x9 3.8 ghz 1.5v (1.48w/droop) 8800 gtx 720/1684/1107 1.47v(Permanent overclock) in the loop
http://img214.imageshack.us/img214/8...ftt3800qb5.jpg
EK Supreme Q6600 GO 422x9 3.8 ghz 1.5v (1.48w/droop) 8800 gtx 720/1684/1107 1.47v(Permanent overclock) in the loop
http://img136.imageshack.us/img136/2...supremeyz7.jpg
Sorry it's not a comprehensive test and only a quicky. Will do some more tests later.
The Supreme just edges it here. Have to allow for a slight difference possibly in ambient temps though. Both decent blocks in my opinion:D
RLM
Wait a minute.. is it the GTX or GT that you have? I thought you had an Apogee GT. There's a difference between the two.
I was hoping for the EK Supreme to blow everything out of the water. Its supposed to be 4C to 5C better than the nozzled FuZion !
I have both a GT and GTX. That test was with the GTX.Quote:
Call me a cynic, but I really wasn't expecting a major difference personally. Others might get better results though. Could be that mine has room for improvement in the way it's setup. As I say no expert.Quote:
RLM
1-2с is more realisticQuote:
maybe there must be a better loop or... another injet plane..
as you can see it is not the performance jetplate
Hope that we get some bowed/nozzled fuzion comparisons soon :)
I think we already have the answer to that question. The prelim results show that the EK Supreme is about equal to the bowed and nozzled FuZion. Its supposed to be much better.
It is by far the best looking block on the market, now if it performs as good as it looks my FuZion will end up on one of my servers. :up:
rLm looking forward to some more testing!!
take some pics of the block installed yeah!!
