Q6600 G0 L737B064
D-tek Fuzion - MCR320 - MCP655
3800Mhz (475x8) 1.392v
Asus P5K Deluxe
http://img264.imageshack.us/img264/3...00primebb6.jpg
PS: New CPU, new BD entry plz :)
Rbs.
:wave:
Q6600 G0 L737B064
Asus P5K Deluxe
Rbs.
:wave:
Guys, do you know anything about this batch L733B421?
Don't know if it's G0, some guy told me it is.
Any info would be usefull.
Hi everyone,
Does anyone have any solid data on G0 Batch L734A?
I have a Q6600 from this batch with a VID of 1.275 that I'd like to get to 3.6ghz on air with a tuniq tower (and perhaps to 4ghz on water later-on.) I have an eVga NF-68-A1 board which successfully ran an E6600 @ 3.6ghz stable (x9 * 400fsb, 1.44 vCore actual) for nearly a year. I tried to get to 3.6ghz with some common settings but ran into trouble.
Over the weekend I'll have to map out this proc's OC capability in a more gradual matter, in hopes that 3.6ghz isn't a stretch. Any information on similar chips would be greatly appreciated.
Mark.
:welcome:
I tested two quads (a Q6600 and a QX6700) on a P35 and an eVGA 680i A1...with both procs, I was stable at up to 3.85GHz on the P35 mobo, but could only get 3.6GHz benchable with the nVidia chipset....I had to drop to about 3.2GHz for full stability.
I mention these results because I don't think you'll be limited by your CPU/CPU stepping...but rather, by your mobo. Good luck!
Here are some folks with results from your week.
1. nonvtec http://www.xtremesystems.org/forums/...157690&page=12
2. qujck http://www.xtremesystems.org/forums/...152603&page=66
3. juliper http://www.xtremesystems.org/forums/...=167671&page=3
4. ea6gka http://www.xtremesystems.org/forums/...152603&page=66
5. roger_d25 http://www.xtremesystems.org/forums/...=152603&page=5
6. roadrunner http://www.xtremesystems.org/forums/...152603&page=69
Most have a VID value less than your 1.2750v
Here is one ex that can do 3.6GHz on a higher VID
1. mc2k http://www.xtremesystems.org/forums/...157690&page=11
Hope this gives you some confidence.
From what I read, some MB are not Quad friendly you may want to look in that direction.
Thank you kindly for the info Miahallen and Wizard. :) It's clear that getting this to 3.6 won't be as easy as "dialing in" speeds and voltages (as I did with the E6600 to my satisfaction.) I agree that the motherboard is most likely to put up the biggest fight. After spending a few hours on the eVga forums last night, I do think it's possible, but it'll take a few days of truly mapping out the processor's full capabilities and a lot of trial and error. Btw, the evga is an A1 revision. In fact, one of the two reasons I upgraded now (instead of waiting for the Penryn) is that I can bail out to a 780i board on the cheap if need be (the most expensive components in the rig, for better or worse, limit me to nForce.)
I do have some confidence, though. I under-volted at stock settings last night to figure out if re-seating the heat sink would be worth while (and with a delta of 14 between idle and load, I think it would...) To my surprise, the system is prime stable at 1v (and I still haven't tested for the stable floor yet.) This should at least be encouraging. Perhaps the VID isn't 100% accurate for every chip.
Mark.
L737B543 ..i suppose iam one of the unlucky with the 1.3125 vid..still manage to 3600 but not prime stable..lower max tempe's need for that..
I have written 1,35V max on the q6600 retail box - does it indicate something? what exactly do you mean with "unlucky 1,3125 VID" ? thanks
The VID is a number stamped electronically into each processor which represents the voltage needed for stock operation (not accounting for vDroop.) It is unique to each processor, and can be read by a program called CoreTemp. While the number is unique to each processor, and while there does seem to be a decent correlation between processors with low VIDs and high OC capabilities, this correlation is not statistically proven.
It's also not necessarily accurate in some cases, as many (such as myself, currently) can undervolt below VID and still run stable at stock. However, the fact that a correlation does appear to exist between VID and OC ability makes it a popular measurement in predicting OC success.
The number on the box is the same for every Q6600 and represents the max voltage to be used for stock operation (although I could be wrong about that.)
Mark.
well, I have a L731 that although having 1,225V VID doesnt OC well - not over 360 FSB stable so far :(
Q6600 @ 4.0 - 1.5 vcore
Batch # L737B
Just did a 6 hour prime run
http://i37.photobucket.com/albums/e8...0stability.jpg
now its time to go to work on 4.1 :D
Nice Oc at that voltage. Is that 1.5v in bios ? Best I can get at bios vcore is 3880 prime stable 11 hrs then I stopped it. What bios settings do u use ?
First day results so far:
• Q6600 g0 L737B242 VID 1.2125
• Asus X38 Maximus Formula
• Thermalright Ultra-120 Extreme
• 3.6ghz @ 1.288 idle/load
Testing & results will be continued...
~ Update ~ Day 2 testing.
• Thermalright Ultra-120 Extreme [ Cpu & heatsink unlapped]
• 3.825ghz @ 1.376vcore idle/load
12 hours Prime small ffts stable. 3.825ghz @ 1.376vcore. Tried 1.368vcore but rebooted between 10-11 hours.
This cpu seems lots better then my previous 1, up to 4.0ghz :up:
Yes I think so, my other got a VID of 1.2875, altho it can do 3.6ghz with 1.408 which is Oke`isch, however for higher it Scales Very bad. I installed also a Q6600 recently for my cousin and it has a VID of 1.325, for 3.4 ghz, it needs 1.47vcore.....but it runs cooler then all the other with lower VIDs for that volt. So I do think there is a direct correlation with Low vids and High O/c if I can rely on just 3 cpu I tested alone, however If u look @ the overclock section, u see that all low VIDS can clock higher then higher VIDs with less volts.
And about the Shape of the IHS it was more like the same as my previous, lapped the Q6600 with vid 1.2875 along with the Thermalright shaved a good 13c off during load :up: Not sure If I need to lap it for now as temperature seems very acceptable.
For the people who got to 4GHZ can you post your settings? Did you have to play with NBv or CPU VTT or anything?
I got to 4320 and my bios setting were pretty much left alone. I changed fsb, ram voltage cpu voltage and disabled spread spectrum. Everything else auto.
http://img529.imageshack.us/img529/5...1spihk3.th.jpg
Congrats buddy! I knew you would like it!!
Here is a little test I did yesterday night:
http://valid.x86-secret.com/show_oc.php?id=289804
CPU-Z screwed my memory though lol
Here is my Quad at 4104 running 4 superpi at one time...
http://img101.imageshack.us/img101/8327/32mfinalvk4.png
