A little fun with the E4500. Interesting to note its smaller L2 seems to have little effect on its performance in this benchmark.
http://img.photobucket.com/albums/v3...7NuclearMC.jpg
repost from the F3 thread but supose It best to post in here offically.
10K A64 X2 :)
10020 Mark @ 3824Mhz DDR2-546Mhz 4-4-4-6-11 2T
http://img187.imageshack.us/img187/2...nuclearyc8.jpg
all updated guys :)
Congrats again mAJORD, that's an insane score you got there :)
Incidentally, you find the low HTx helps with OC or were you just testing?
Nice seeing the big guns from the AMD bench rolling in...if only Jiu-Jitsu's board didn't have a bad flash yesterday when we finished setting it up, we were gunning for 14K easy. Looks like we'll have to wait a couple more weeks....
Oh and Soldner, I think you need to move Jiu-Jitsu's score up 3 spots. Forget how to count? ;)
Thanks for posting your benchies msimax! Looks like you and Jiu-JitsuGOD can have some fun going back and forth once we get his rig back up and running.
all updated
not till i get another psu i had to turn off all fans uplug cdroms disable everything in the bios and by the time the multi core test came i turned off my water pump took me 5 hour so this is it :rofl: :ROTF:
http://i31.photobucket.com/albums/c3.../nuclearus.jpg
8748 marks for a stock system.
Weak score for a POS CPU. I doubt I'll keep it but here's about the best it could do.
http://img.photobucket.com/albums/v3...ron1802784.jpg
here you go ;)
http://www.xtremesystems.org/forums/...1&d=1189648008
Here's mine, nothing amazing, any higher oc and system is unstable...fiddling to try and increase still though :P
I got a new Q6600 GO from the egg, TN. warehouse, batch L726A840, 1.325vid, pack date 8/14/07, here's a run two hours after install. More tuning needed.
Attachment 64331
New run:
http://img527.imageshack.us/img527/6876/9943ke3.th.jpg
9943
heres mine-
http://img.techpowerup.org/070919/nuclearus.jpg
22300 @ 1.51 Vcore
http://img521.imageshack.us/img521/1...ear4145wn2.jpg
Water 20* ambient
Heres mine E2160 @ 3474Mhz
Hey Folks..
As mAJORD did, I posted this in F3 OC Thread. So I figure I cross post it over here. So here is my score: 10319 :)
http://www.ironmods.com/ForumImages/...ore_10319b.jpg
Please put it under "TiTON" :) that is my HWBot nic.. just want to make it consistent :)
Ton
Grrr, can't quite break 10k....getting closer though :yepp: :D
