Anyone played around with the SLI memory option in the bios and found it useful??
Actually I was being sarcastic about the 401 because the only real difference I can see is that it has the sli-ready memory option. Im using the 401 beta thats been floating around a few days. Maybe I should flash to the official 401 just to make sure they are the same. 419 FSB 1:1 4,4,4,12 1T 3769Mhz is the best stable overclock I can do so far. At 423FSB I get errors in memtest no matter what the voltage. I get better performance at 3.67Ghz 408 FSB mem 408 4,4,4,12 1T than I do at 3.8Ghz 475FSB mem 475 4,4,4,12 2T. I just wish I could see all of the memory sub timings the bios auto assigns. This is still a very good board for the money. @ John44 I don't have sli memory so I can't say.Quote:
Originally Posted by Merc14
It looked like, as I was going through the manual, that all the settings for RAM became avaiable when unlinked was selected. The big drawback is there are only three dividers but then you can change the QDR speed etc.etc. :rolleyes: I am in sponge mode.
I have a steep learning curve ahead coming from a strictly AMD background. I can overclock them in my sleep but Intel is a whole different animal. The last Intel I O/Ced was a P4 Northwood on air. Very nice chip BTW.
Originally Posted by Highland3r
that sure is an awesome 1T clock, I've changed the NB cooled to a Noctua heatpipe thingie but that didn't make a diff, eventhough temp got lower. It still maxes out around 365. What bios are you using?
Pretty sure it's not maxed there too :)Quote:
Originally Posted by zeeke
Bios is whatever came with the board, 0202 i belive :)
Have you tried MemSet 3.1 It will show all the sub timings in Windowshttp://rv.page.cegetel.net.perso.cegetel.net/MemSet.zipQuote:
Originally Posted by Ron 61
Memset shows most but not all of them. I just wish the bios would show what they are auto set to.Quote:
Originally Posted by John44
Hmm, that is just strange.. I mean, my board is memtest #5 stable for hours @ 366mhz But get 1000+ errors @ 367. Im startin to think this is a bios limitation..Quote:
At certain frequencies the bios changes "straps", which leads to a whole slew of timing changes that you don't see. Other times there are holes in the frequencies that just don't work right for anyone. Try 368 or 370 and just skip over 367. Alsoyou might need a little more juice going to the northbridge.Quote:
Originally Posted by dlxmax
The straps are for the FSB, not memory speed. And NB-voltage doesn't make a difference. I'll try a bigger leap though and see what happens
Guys, we all know this board has a big vDroop problem, and some members are working on a cure. But right now we need some help. We need someone with a multimeter to take a couple of measurements to backup someone else's findings. I left my multimeter in 'merica, so I can't help. But can you?
Visit the thread: http://www.xtremesystems.org/forums/...96#post1968396
Oh, and zeeke, I've read on another thread (at AnandTech) that people have acheived greater memory speeds with increased NB voltage; bump it up to 1.39v. Also try lower/raising your mem voltage. Yes, lowering sometimes works better. I've had my mem up to 1050 and it's just some non-Micron SuperTalent PC6400 memory.
Try and set memory and FSB speeds (when running unlinked) to end in 2,4,6 or 8. These seem to help on the stability front. Also double check your memory speeds. You may find setting 366 unlinked doesn't give you 366 "real", 367 then moves you up to the next divider.Quote:
What ram/setup you running btw?
<edit> Guessing from sig its the Team stuff? shouldnt have a problem at that speed, where's your CPU running? Assume your using 2T timings and 2+v on vDimm? </edit>
dlxmax: its not the memoryspeed im trying to increase per se, these puppies do well over 500 with 4-4-4-10-2T on this board, I want to increase the 1T max.
I'll have a look at those measuements when i get home from work, personally I haven't experienced the droop as bad as coupli. Last night I measures vdrop during 2x32mb Spi and with 1.57V idle it drops to 1.53V-1.54V during full load. That is real though, the probe is showing ~1.3-something.
Yeah its the team mem, but its the 1T i want to increase as staded before. @2T these mem do over 500 easy @ 2.4V (real), 2.3 chosen from bios, but the board seems to overvolt the mems a bit.Quote:
Oh, another thing Ive found ut, the vdrop for the CPU is worse with the +100mV option enabled.
Chipset voltage and cooling may help you out there then. Stick it up to 1.75v option and see if you can push any further.Quote:
Gskill kit (6400 C4) maxed at 422 fsb 1T, more voltage, looser timings etc didnt help. The crucial seem's to run MUCH better under the same conditions.
You have to up the volts to northbridge if you want higher fsb 1T. Anything above 400 fsb 4,4,4,12 1T on my board requires 1.74v. Ive ran 1.74v on mine for a month. Currently benching at 423fsb.
I am running NB @ 1.74V still doesnt matter,
Highland3er-
Are you using the CPU overvolt option or do you have it disabled? On the A8N32 SLI, CPU Overvolt stabilizes the voltage and I was assuming it was the same on this board.
zeeke try different fsb, mine will not boot at 412, but will run prime at 413. You may be trying to boot in a dead area of fsb.
Didnt seem to make much difference either way. Usually run it to try and compensate for the vdroop.Quote:
Zeeke,
Not all RAM can run at 1T ... I had Corsair XMS2 PC2-6400 (2x512) .. I cannot set it to 1T; however, I have had no problem with my OCZ XTC Gold RAM.
You might want to change TRc .. it might help to run at 1T ... :D
Yup. I've not found any setting that worked at 1T with my mem either. Some say the bios settings are too aggressive to allow a lot of mem that would run at 1T on other boards to run at 1T on this board. Perhaps a future bios will fix this. Until then, be with me at 2T ;)Quote:
Originally Posted by sbinh
Try stepping over 400 - 424 and jump to 425 426 FSB for 1T I have found that I can run timings at 4-3-3-9-1-2T and get pretty much the same performance as 4-4-4-12-1-1T
EDIT: I think cooling is the biggest issue with this board especially the NB. Last night I opened my window and let the cold air drift into the box and was able to reach my best OC with .05 less vcore set at 1.475 (usally 1.52) and the NB at 1.56 (usally 156 - Max) and I seemed a hell of lot more stable.
http://img177.imageshack.us/my.php?i...uz485x83on.jpg
This is a compare between different memspeeds, all other settings kept the same. It doesn't really make a difference, atleast not in 3dmark06, Superpi is a whole other beast though..
http://www.bandwidth.se/imgs/16/17/4...110918.gif.jpg
Any new beta's out??? I need my 7950 working :P
