Hmm, multi maxed out with those other BIOS @ XX
>14X with 0022.Quote:
Originally Posted by Dani
I am in the same boat as you, with 1.55 v in windows, 2.2v on RAM and all other volts maxed I can't get past 390x9. I can boot into windows at higher speeds, but prime hard locks my rig in under 1 min. My DS3 overclocked better than this board for less than half the $ :mad: New bios is more of the same, nothing improved for me.Quote:
Originally Posted by Ibinco
On the good side, this board has no problems with my Xfi, unlike the DS3, and I don't have to listen to the inductors on this board whining like a little jet engine. I think when I settle on a 24/7 overclock this will be a fast and stable board, and Crossfire is a definite possibility now.
Blagh. RAM is only good at 530. Trying 530 @ 4-4-4-1. :toast:
1:2 divider.
What revisions are you guys'es that arent clocking so well, im hoping this isnt linked to the new 975x revision ive got on my northbridge.
turned multiplier down to 6, ram down to lowest dividor, relaxed timings all the way, then cranked up all the volts to max bios allowable.
Couldnt even boot above 390, not happy with that at all for a "470 out of the box mobo". I have C1E and speedstep off, unless im missing something else, my 300 bucks board appears to be a dud, which sucks because i can tell my CPU has got a ton more in it (b1 ES).
This board can go 470FSB, but it all depends on your cooling, ram and psu.
I tested five PW64 boards and all performed the same.
My specs. stay the same: TT Big Typhoon with Delta 120EHE 190CFM, Corsair 6400C3 and Zippy PSL6850 850W psu.
One board is up in smoke though...Dead dry.....
http://img503.imageshack.us/img503/8...shot046uw2.jpg
Newest one...Mobo kinda bent because of tight mounting.
http://img85.imageshack.us/img85/463...shot067ih3.jpg
wow!:eek:Quote:
Originally Posted by Dumo
horrible QC.....
reminds me of my Foxconn 975x AB board that caught fire on me.:D
Its not a QC problem:DQuote:
Originally Posted by kenofstephen
Its because of condensation when running with cascade @ -90C:(
:slap: :slapass: your problem :fact:Quote:
I didn't complained about the mobo:)Quote:
It won't boot at 400x9/1067. :(
Had to go w/ 428x8/1070. =/
I need better cooling. I don't know how I'm getting 60s load w/ WC. :(
you didn't :DQuote:
Hmm not sure what the problem is, my cooling, PSU, and RAM are all perfectly fine. This RAM does 950 at these timings, so 800 shouldn't be tough at all. Iwaki + Storm should be plenty adequate for the CPU, the chipset blocks have been cleaned and Ceramique replaced the crappy pads. I have a 120mm Yate Loon blowing directly on the RAM/Northbridge area, the heatsinks barely get warm now. My RAM is in the yellow slots, that seems correct. Maybe this board hates my Ballistix?
But thats sick, I know this CPU only needs 1.4875v for 3.8ghz overclock on other boards. e.g. DS3. And on this board it needs 1.5v bios----> 1.54 windows just to run 3.7ghz? Thats bogus!Quote:
Originally Posted by Complete
Thought this might be a good place to pop in ;)
I have tested many combos out on this board now and tried multis ranging from 6 to 10...
So far the highest FSB I can boot with is 455. Now I can Clockgen up to 470 after booting at 455 FSB and x 9 but it quickly becomes unstable at 470 and crashes.
Settings for me:
vFSB (1.4)
vMCH (1.8)
This board is by far the best based off of the 975 chipset but it will not go higher for me even using after market chipset cooling (not watter). This poses a problem for me becuase I have an ES e6700 on the way which can make use of the higher FSB. How much does the pencil mod for vMCH help out?
Just thought I would pass this along to folks...testing chip was an x6800 and phased...
Stupid question but your pict has me worried. When I removed the stock passive cooling last night I added a single aftermarket chipset cooling to the northbridge only but after looking at your picture it looks like heat may be a problem for mosfets too....how do you cool them after removing the stock heat pipes?Quote:
Originally Posted by sdumper
You could cut the stock heatpipe off at the cooler & put that one back on.
Sorry I haven't read the whole thread.
Any confirmed vcore measuring point??
Thanks for your help
Originally Posted by Icer
Interesting idea ill try it...thanks
:stick: Hmpf - always been and always will be........;)Quote:
So at least put a 120mm fan in front of...........:slapass:
http://img.photobucket.com/albums/v1...-vmchmod-1.jpgQuote:
Originally Posted by ojdr2001
he said it was a condensation problem..not a cooling problem...Quote:
I didn't used to think they got hot either, I just thought it was the actual capacitors (those big black blocks) that got hot. Having sinked my MOSFETs though I can say that with loading on the CPU they get very hot indeed.Quote:
Originally Posted by camouflage
http://www.superficial.net/miscstuff...rm_cooling.jpg
