Updated BIOS from 1604 to 1803.
Kind of annoying initially some settings were hidden/missing (need set bios default and extra reboot to fix).
Had little mishap with Vdroop mod - at stock settings, Vcpu was swining wildly from 1.05 to 1.3V - hope you guys and hals put some tape over the area so mr graphite does travel around. Nonetheless, very hot NB issue remains - dont recall it ever being like this, especially when room temp is ~15C - might have damaged it from all the months of overclocking.
FYI, for those curious, at 200Mhz fsb (for cpu which use "800fsb"), available memory multi: 533, 667 and 800. This corresponds to 4:3, 5:3 and 2:1
at 221fsb it switches to different ones, at 266Mhz fsb memory is: 533, 668, 801, 890, 1068. This corresponds to 1:1 (my fav!), 5:4, 3:2, 5:3, 2:1.
...Still trying to figure out hissing/popping with onboard (except when using rear speaker jack), and 5-6C difference between core1 and core2...
btw: the setfsb util works marvelously.
Anyone have E8x00 cpu on this mbo? I can asume it works well, because wolfdale is a good match with P965 chipset.
Seeing what can E7200 do (about 3.9-4GHz with no more than 1.3V vcore) i'm willing to buy one and replace good ol' E2160. :)
