Oh this is bad...Quote:
Originally Posted by TaPaKaH
mine can hit 500fsb.. benches easily @ 476 x 8 @ 3.8ghz...
The board's rev, shows 1.03g...
Does it says anything??
http://valid.x86-secret.com/show_oc?id=133052
with 2.9vdimm and losse timmings , mobo is realy holding evrything back !
gone test with p5w dh if it gets back from rma
I don`t know.
Mine previous one got 640MHz mem easily : http://valid.x86-secret.com/show_oc.php?id=125164 (Vmem ~ 2.85V)
idd i have to run 5-5-5 to get 600mhz max , gone test on a p5w dh to be sure or els there gone and something new :pQuote:
I decided to go with the Dlx board, it costs a little more but I can afford it :)
since tomorrow I also will be a DLX user :D
I'm using 0701 and mine constantly cold boots. It's pissing me off, i think it's maybe not done it 2 or 3 times. Is there a setting I can change???Quote:
Originally Posted by Vric
same here. I thought 0701 fixed the false start problem. My overclock is lower after 0701 also. Anyone else have a lower stable overclock since you flashed to 0701?
mine is death :(
Hi guys this is my 1st post on this forum :) gonna jump in to action.
any how here we go.
system specs:
Intel E6300 466x4 1.350v box cooler
ASUS P5B 1.03g 7101 bios
Corsair XMS2-6400 C5 rev5.1 1gb @ 466 5-5-5-15 2.1v
MSI 7900GTO 512mb 700/750
PSU: TT 420watt
http://img176.imageshack.us/img176/8122/3250mhzfs3.png
http://img525.imageshack.us/img525/4855/pi17828ct9.png
now this system works in most aplications but crashes each time @ 3dmark05 in the CPU test 1 if fsb is above 400 it crashes each time. :<
tryed my memory @ 4:5 it faild. but when using 466 combo 1:1 almost all of the test programs work with out reboots, tryed upping the voltage on cpu and FSB no luck same effect reboots @ 3dmark05 altho the 3dmark06 works fine.
Tryed almost all settings that effect o/c in bios still no luck. maybe memory limitation
Hi guys,
Has anyone tried Linux on this motherboard?
If yes which one.
Also late Macintosh operating system ?
V.
Nice clock. I have a very similar setup. Intel cooler? Nice. Bios 7101? Do you mean 0701?Quote:
Originally Posted by inz1
What other settings have you used like vfsb, pcie, pci etc
Guys. I need some tips on how to install a 40mm sunon fan to the NB HS. What type/size of screws are needed? Or is there another method besides screws?
box coolerQuote:
Originally Posted by stark27
ye i guess 0701
vFSB from auto to 1.45
PCIE - 100
pci - 33
but still system aint stable :< 3dmark05 makes her go reboot. :< imo i must play with memory timings.
Any feed back on new BIOS (0806)?
http://support.asus.com/download/dow...n-us&model=P5B
Thanks for the tip, did not know it was out.
The only thing I noticed straight away with the new bios is my PC does not cold boot everytime I enter bios now. Apart from that, no cool new features like NB/SB/MCHsettings or more vdimm options =(
Yeh mine doesnt cold boot either :DQuote:
rest of the settings shud be the same altho even i wanted Vdimm higher than 2.1V:(
What's the most stable bios so far for the ASUS P5B?
Take the last bios available.
Hi guys,
First time posting here.
I still have a cold-boot problem with the 801 BIOS. I only have this cold-boot issue when I'm running overclocked though (7x400; 2.8GHz x 1600MHz).
Just to make sure though - a "cold boot" is when you go to restart from Windows, and the machine completely shuts down, then starts back up (instead of continuously running during the reboot), correct?
Also, does anyone else notice a small fluctuation in reported cpu speed on POST? Sometimes mine will say 2.81GHz; sometimes 2.80GHz. Not sure what that is all about...
One more question -
Is there any way to automatically skip the JMicron detection portion of the boot process? I have a SATA drive (my boot drive), a spare IDE ATA drive, and a IDE DVDRW drive in the system. The JMicron sees the two IDE drives, but shows nothing of the SATA drive on this screen. Im not running any RAID or anything... This just seems like another delay to get to windows...
Thanks for any help!
-Ryan
Have you tried it? No problem at all? Like random reboot, cold boot...cuz I've to buy the mobo and for the price it seems the best out right there...Quote:
Originally Posted by wittekakker
hiQuote:
Originally Posted by Vasilii
i tried that one and had to rollback to 701.....
i have mine with vdimm and vdrop mod
its not amazing but for the price......
just a quick run with ...
E6600 29B2...1,67 vcore...measured
2x1024 cellshock 2.55 vdimm...measured
p5b...of course...:D
7300 LE
bequiet dark power 600w
WC with nexxos xp silver and BIX 240
32m
http://img135.imageshack.us/img135/7...2m52516jf2.jpg
1m
http://img247.imageshack.us/img247/7639/12469li9.jpg
i am still waiting for a dfi lanparty to come out and this budget board...with the vmods...suits me just fine
regards
Same. When I first updated to 0806 the cold boot went away, now it's back. Not happy Jan. But I've noticed that if i Load Defaults it goes away again until I OC.Quote:
CorrectQuote:
Never Noticed.Quote:
I'd also like to know how to do this but still have not figured it out. But I know where to diabled JMicron in the BIOS, I'll try that but I think the IDE devices wont be detected in POST then.Quote:
If you're using the Intel SATA ports, then it won't show you the SATA drives in that JMicron screen.
I have a newbie question though. I have Intel C2D E6300 and some Corsair RAM, TwinX 2x512 5400 C4 (675 MHz). I'd like to know how to overclock it slightly so that my memory will run in sync with the processor (now it runs in 4:5 ratio, I think, processor at 266 and memory at 333). I'd like to run both in 333. The problem is that when I change the settings in BIOS and save, I just get a blank screen and nothing happens. I have changed the CPU Frequency to 333 and DRAM Frequency to DDR2-667. I've also tried "locking" the PCI-E Frequency to 100 MHz and PCI Clock to 33.33 MHz, but that doesn't change a thing. I'm only looking for a very small overclock, for now and I can't even get that to work.
You have to change DRAM frequency to DDR2-533 (1:1). Setting DDR2-667 you're giving setting a 4:5 FSB:DRAM ratio, which means you mem is actually running at 500mhz :oQuote:
Originally Posted by daimaah
Also, you may have to increase your vmch to 1.3 or 1.35v.
