this will probably be my 24/7 speed while i'm using air cooling :shrug:
http://img170.imageshack.us/img170/6070/8hfu4.png
E6700ES @ 3.6GHz with 1.425V
Intel D975XBX 'Bad Axe' Rev 304 (1351 BIOS)
1GB Kingston PC8500
1GB Kingston PC8500
Dual Spi32m 3700mhz@1.55V (1.5V DMM)
http://img183.imageshack.us/img183/7...lspi32myf3.jpg
Orthos 3600mhz 1.55V(1.5DMM)
http://img183.imageshack.us/img183/8...mhz155vdl8.jpg
This is the Core 2 Duo Overclocking thread, any overclocking results can be posted. Needless to say, benchmarks count.Quote:
Originally Posted by famich
If you want a stability testing thread you can make one, but you won't get as many posts in it because some people (myself included) think that running hours and hours of prime is a waste of time. I usually stop it after 30 minutes.
We had a discussion about that before, but how do you test your stability then ? Do you test it in games / e.g. Oblivion , which is IMHO very CPU demanding / or how ?
I agree that 8-12 H is a lot, but let us say 2-3 H seems OK to me , if you dont want to be afraid of locking up in the middle of ...
my e6400 is stable at 3.44 with 1.5vcore. Is that a little too high? idles at 45C and dual prime brings it to 53C even after 10 hrs. (core temps) Its a week 26. I thought the newer weeks OC better with less vcore?
Can anyone tell me how I can change the multi in the BIOS? I think it's in CPU configuration but it is locked.
On P5W DH u cant change multi in bios (yet), however it can be done with a program CrystalCPUID (function/intel inhanced speedstep control).
The magic 4ghz, here I come :D :banana:
http://img179.imageshack.us/img179/4955/39ghzsb4.jpg
Thanks!Quote:
Originally Posted by Shark-357
Have been torturing my E6300 and P5WDH somewhat,this is what i have achieved so far.:D
http://img132.imageshack.us/img132/6099/9ka4.jpg
Just took some nasties off my E6400...
http://img.photobucket.com/albums/v2...0/IMG_1138.jpg
http://img.photobucket.com/albums/v2...0/IMG_1142.jpg
Looks like 4C better idle, and 7C load. Def worth the time. As a side note, I lapped dry instead of wet this time. Results were a bit less satisfactory, but it took A LOT less time. Did the Zalman too since it had machining grooves I could feel.
1M @ 3.4GHz and BSOD'ed soon after.
3.2GHz dual primed for 10 mins till I got bored and aborted...
On Intel stock HSF.
CPU: E6400 @ 3.51 Ghz
Batch: L624A780
Motherboard: Gigabyte GA-965P-DS3 Bios F3
Memory: 2 x 512MB Corsair PC6400C5
Cooling: Boxed
FSB: 439
Memory Mult: 1:1
vcore: 1.4v
vdimm: 2.2v
http://img169.imageshack.us/img169/2526/439dt1.th.jpg
With Boxed :)
I'am gonna try now 3.6Ghz with my new Artic freezer 7 pro :toast:
CPU: E6300ES week17 @3.6GHz
514MHz FSB Asus P5B Deluxe (0607BETA Bios)
1.45V BIOS ~ 1.38V Load Windows
30 minutes Orthos Prime
514MHz G.Skill HZ sticks 4-4-4-12 2.3vdimm
http://img178.imageshack.us/img178/6...minutesbp8.jpg
just looking the super pi speed 17s? My e6600 at 3.1ghz does it in 16. So does this mean the 2mb extra cache comes into play?Quote:
Originally Posted by The_Hardstylez
specv yeah the extra 2MB cache has a big impact on SuperPI scores
Yeah, the 2 MB extra on the conroe make's a big different in superpi.
3700@410x9 VC 1.525V
SPD mem timings MCH1.6V :)
Tallman - 3754 Mhz Dual 32m stable (1.6v) | Air_Sythe Mine 3 | P5W DH 1101 bios | OCZ 2*1Gig PC2 8000 EL Platinum Extreme Edition 4-5-4-15
Boot right into windows
http://img168.imageshack.us/img168/1...32mcpuzsd8.jpg
Boots to windows @ 3844_1M
Both these runs with 1.6Vcore set in bios and bits as per sig :D
1M @ 4072MHz
http://i16.photobucket.com/albums/b2...0ne/1M4072.jpg
32M @ 4005MHz
http://i16.photobucket.com/albums/b2...ne/32M4GHz.jpg
P5B-DELUXE(no mod)
E6600 L627A
air cooler:HR-01
http://i111.photobucket.com/albums/n126/ruei0888/A6.jpg
hmm...Quote:
Originally Posted by alpha0ne
only ~19sec faster as my E6300 @ 3.6Ghz :stick:
zevia - 3200 Mhz Dual Prime Stable (1.35v) | Air - Big Typhoon | Asus P5W DH Deluxe BIOS 1301 | Corsair 2x1GB PC6400 (1.9v)
E6400 Retail @3.2Ghz [1.3500v]
ASUS P5W DH Deluxe BIOS 1301
Corsair XMS2 2x1GB DDR2-800 5-5-5-12 [1.9v]
Thermaltake Big Typhoon CL-P0114
Idle 35-36C, Load 46-48C
8 hours Orthos (complete settings in this post).
http://upload.cdfreaks.com/zevia/C2D...alprime_04.PNG
E6400 @ 3.6Ghz (1.42v)
P5B Dlx (vCore, vDroop, vMCH, vDimm Mod)
2GB GSkill HZ @ 2.1v
Watercooled
http://people.freenet.de/chris070719...-1/Prime-1.jpg
max. 1M Pi @ 1.46v
http://people.freenet.de/chris070719.../SuperPi-1.jpg
Guess not all chips are good.
Best I can do with my e6400 and P5b Deluxe is 2600mhz with voltage on auto.
I tried for awhile to get it above 330 using 1.5vcore. I also bumped up the Northbridge voltage, and ran my Corsair 6400 at 2v instead of 1.9. No dice.
I also went straight to 400x8 since some say 350-400FSB is not good on this mobo. At least it booted to Windows...
Temps were only 55c full load.
If anyone has any ideas please let me know...
