Thanks for all the work on this! :toast:Quote:
Originally Posted by Big_Sam
I'm going to make a 7900GS or 7950GT setup and i tried sownloading the new 84.56 mod2 and the link apperars to not respond or maybe it's a temporary prob.
and my mirror:
http://rapidshare.de/files/34772038/84.56_mod2.exe.html
Thanks for the link! I believe that they're the new mod2?
yo same, is there a way to make it enable LSI all the time?? cuz i find it disabled after i reboot, even though it shows as enabled . Its actually disabled, i ran some 3dmark and doom3 test.
i had to disabled it and re-enable it ever tiem i reboot to actually enable it. before i disable and re enable it i got 65fps in doom3, and i got 128.5fps after....
is there a way to enable it all the time even after reboot??
I had this exact same problem that happened with any of the modded drivers I tried. I'm currently in the process of selling my 7900GTs for a 7950GX2, as I could find no way to correct this issue. Only way I could temporarily fix it was by reinstalling the drivers each time it occured.Quote:
Originally Posted by theteamaqua
Are u experiencing this prob with both 85.96 and 84.56 modded drivers?
It happened with 3 different drivers for me, including those two.Quote:
Originally Posted by JoeBar
So is it a general prob with 975X and SLI?
I'm thinking of changing my setup to a P5WDH (or AW9D-MAX) along with 2x7900GS (or 7950GT) and would like to know about any possible probs.
i know why, when i have my ipod connected to my comp via usb and itunes shows up. it messed up SLI, so u can just disable SLI , then re enable SLI then its back, not a big deal, but kidna annoy.
Hi,
I have a trouble with my SLi on Giga DQ6
i tried 84.66, 85.96, with and without (not flexible) SLi Bridge
I gun 2x 7900 GTX ( tested each one alone, without any bugs or atifacts )
The trouble is in 3D mark, graphics are corrupted , or simply goes to black screen , or froze ... i tried to flip the bridge but no way, i did a fresh XP install with directly the 85.96 but same issue ...
Now i'm resigned to sell one of my graphics card...
My system :
Mobo Gigabyte DQ Bios F3
CPU E6600ES STep5 B1 @ 4050 Mhz ( 450 x9 ) + Vapochill XE II
2 Go of DDR2 Corsair
700Watts Seasonic PSU
2 x PNY 7900 GTX stocks clocks
1 Raptor 36 Go
1 Maxtor 300 Go
1 Samsung DVD writer
PS: the frequency of my CPU is stable, i ran 3d Mark 01 for one entire night
Could you help me ?
PS2: I did 2 days ago, a score of 62000 in 3d Mark 06, but my windows was crrapy, i ran this session without any bugs or issue, but in order to have a fresh and clean windows, i format and re install, now i have issues...
here'a a link of my score :
http://www.cooling-masters.com/forum...gi-family.html
at the bottom of the page 2 ...
this system gonna make me depressive ...
Big_Sam:
Will there be further driver patches available regarding SLI feature for these chipsets ?
Iam not having any of these problems with the 85.96 driver....About the only problem is in Call of Juarez I just have to turn off SLI to play it. Otherwise My SLI has of yet to just disable itself..Been running or over 2 weeks now..Iam running the MSI 975x board..Could this be a board specific problem...
Using the Asus P5W64-WS mobo, XP Pro, two BFG 7900 GTX's and Big Sam's 84.56_mod, the driver intalls without any error messages but does not recognize the second video card. Anyone else have this problem and find a workaround? Thanks
the 84.56 works perfect here.
which slot´s do you use for the gfx? i have the same mainboard and no problems with my GTO sli.
any working ones for 7950gt yet ?
I have added support for 7950GT in 84.56 and in INF file for 85.96, but till now did not see any result in ORB on these cards. :(Quote:
Originally Posted by graham_h
I saw only this results: http://www.xtremesystems.org/forums/...0&postcount=17 :)
I'm waiting for the SLi Bridge to arrive and I'll start doing some benching with a Pair of 7900GTOs!!
PCIEX16_1 and PCIEX16_4.Quote:
Originally Posted by webwilli
Please disregard -- got it to work in those two slots. Yes! I would have tried different PCIEX16 slots, but couldn't because I have a Aerca SATA RAID card that uses a PCIEX slot too.
Thanks Sam. I bow to your bigness!
Mac are running Asus P5w64 Pro?Quote:
Originally Posted by MacClipper
I am having the same problem?? did you find a solution?? I have Corsair C3 DDR2-400 ram.
Will these drivers work with 7900GS's on a MSI 975X? Also anyone know were i can get an MSI SLI bridge to work on this mobo???
no, thats a mac theme :stick:Quote:
Originally Posted by Complete
its problem bacause its not official and, isnt tested to work on everything
but there isnt any performance kinks?
if there isnt, stop whining lol... its just 80 or so mb
7950GT work ok with Big Sam moded driver's V2. Already in single mod, but work !Quote:
Yes 79GS it's work on MSI 975X. MSI SLI bridge ? Asus flexi and anything is ok.Quote:
Originally Posted by Lt_JWS
Originally Posted by BulldogPO
Have some weeks already passed? :D
99 % I know that in the nearest 2 months exact nothing will be.
And very difficultly to tell what will be further. :(
I just tried it out with my bro's 6800GS's lol, worked great, thanks for your hard work on this Big_SAM :D
Big-Sam just a quick question are you already begun with trying to mod the 91,xx drivers???
