I've waited so I don't have to deal with it. :D
SInce that K10 thread got closed,I will post my reply to Vapor here :) :
Yes you can compare it per core.Read again what i wrote.
Scaling is 1.85 for dual core K8.
K10,1.6Ghz ,4core - 814.
K10,1.6Ghz,2 core - 440(with scaling of 1.85x from 2 to 4 cores)
K8,1.6Ghz,2 cores(1MB of L2)- 445!!!
So by this we get that K10 is supposedly slower than K8 per core in this test.And test was done on AM2 mobo!
This tells me that that was some early buggy revision with who knows what deactivated trough bios,with sole purpose of demonstrating the performance/watt claims AMD made in the pas(Double the cores ,keep the same total system consumption and double the performance
It is possible that many of new features in this Barcelona sample was not working/broken.
Cinebench itself was ran in 32bit mode under 64bit OS.. how strange.
My old X2 3800 clocked@2550MHz was getting 874 points under 64bit OS/test.
This test proves that CPU is 'working' not only in Task Manager, but I wont be judging my opinion based on just one benchmark with preproduction sample run under unknown circumstances.
Here is my 25 seconds on my FX60...
2850 mhz.. 285 TCCD
K10 fails hard, it cant even beat K8.
http://www.sspmustang.com/OT/ggseanpwntby2850tccd.JPG
Either Barcelona is having serious problems, or AMD is intentionally showing us junk. I'm losing any confidence I had left with AMD pulling off the upset against Intel with K10. At this point I think AMD will be lucky to repeat Barcelona like R600.:(
Amd fx 60
Maybe that is the ipc performance is just the same as K8, but it'll clock higher like the Netburst Intels.
Maybe. But most likely L3 cache was disabled in bios "in purpose" to show or it was pre-release sample with disabled L3
don't you just love how much FUD that Intel seems to love pumping out lately?
If I got a Nickel for every bit of FUD that came out about K10, I'd have a :banana::banana::banana::banana:load of nickels
Intel demoed the dissapointing POVray and Cinebench tests? :rolleyes:
What's really disappointing is the kind of shrill coming from Anandtech. Anand used to be a balanced guy, comparing AMD and Intel, but ever since Conroe he's been decidedly pessimistic and negative on AMD. The moment I saw his review being quoted and plastered all over the "official" Intel slides, I knew his time of being an impartial reviewer was over.
Kinda sad, since Anandtech was a reasonably good place for reviews in a time when THG was the #1 Intel fanboy site. However, THG has since toned it down considerably, and Anandtech has instead taken that #1 spot.
K10 doesn't run CPU-Z ? :shrug:
http://www.fudzilla.com/index.php?op...=1342&Itemid=1
i don't know why go attack anandtech
they are probably one of the most reliable review sites out there. if it hurts you that Wes and Gary tell it like it is because you are a fanboy of the brand that gets plastered that is entirely your problem and you should not blame them
i know that nn_step is clearly one sided much like the Iraqi Minister for Information :rolleyes: but it seems that he's not alone here
What is wrong with being pessimistic and negative towards AMD? What positive do they have to...be positive about?
