I found on my board I could not get 266:800 or 333:800 to work...not sure why(well 266:800 is way too high mhz on my ram)..but 333:800 should be fine since my ram would have be at like 460(it will run winxp at 487 or 266:667)
How do you get 487mhz (266:533) at 390x9? According to the strap calculator it should be 391mhz.
Anyways I think it was my Everest version. Woke up this morning and I passed Orthos 8 hours with load temps right at 60 degrees. Saw gtj's post so I went and downloaded the newest Everest trial and refreshed the benchmarks a few times and no crashes yet. This is at 5-5-5-16 though so I'll have to test more later :)
I can't seem to hit 3.6Ghz
Below are my settings:
FSB = 400X9 (bios 2333)
vcore = tried 1.55 to 1.6 (everest states vcore as 1.5v when bios is 1.6v)
vmch = 1.625 to 1.7
vfsb = tried 1.425 to 1.45
vdimm = 2.2
timings = 5-5-5-15
ram ratio = 266:533 (1:1)
idle temps = 51-52c
load = 68-71c
* failed orthos in less than 5 secs.
** pass memtest+86 at 400FSb (4-4-4-12 and 5-5-5-15) for 2 hrs
***C1E disabled via C1E inf file, EIST disabled, power slope enabled, VT disabled, all unused ports (parallel, 1394, cpu fan control) disabled
Please help !!!
My old E66 (L630A) can do 3500 @ 1.49V.....3600Mhz maybe with DI and 1.8Vcore :rolleyes:. I never get it stable @ 3.6Ghz :slapass:
My new E6400 (L626A) can run at 3600Mhz @ 1.42V, 3700Mhz @ 1.48....My BX2 tops around 440FSB on 266 strap, and 465 on 333 strap. Orthos stable.
It's just luck...:(
So...now what ? End of the line?
Gtj & shimmishim, some help plz if you are seeing this
about memtest
I find test 5 and 8 to be the ones i get errors in if something is wrong
for me 5 tends to be NB error and 8 tends to be the ram
ddr2-1000 tracerx
Perhaps I'll give that a try. Strange that it's been working stable for weeks at my vMCH of 1.55v. I'd love to know what happens in the MB when a blue screen occurs. Seems like USB devices play some kind of role.
p.s. I finally managed to get around to updating my signature :)
Well my comp is 20 hours Orthos stable at 3.42 GHz. Just ordered the Thermaltake Ultra 120 Extreme so I'll wait to get that before I try for 3.6. Pretty happy where I am now, temps on load are at 59-50, idle 41-42 or so.
vcore 1.4500, vfsb 1.350, vmch 1.550, memory was at 5-5-5-18 2.20v. Now it's time to try and tighten the memories. Hopefully they will still do 4-3-3-4 like it did at 3.24GHz.
Ugh. So I updated the BIOS to 2692 using the Express method. I figured I might as well since I had to get in there to change my vMCH setting anyway.
BIOS update worked alright, until it went to load windows... or more like DIDN'T want to load windows.. or anything. It would give me a black screen with a blinking prompt, and that's it. Wouldn't boot from any device (even USB). My RAID & boot device settings were all good, it was driving me nuts. After maybe 15 tries with various settings, I finally disconnected all hard drives and left a bootable CD in the Plextor.
What do you know? It booted. No idea why it was hanging up before. I plug my drives back in, and well... here I am. Back in Windows.
This board is a real headache sometimes! I don't know why it was doing this.
On a happy note, I am running again at 266:800 @ 4-4-4-12. I had to up my vMCH to 1.575.
- Sker
Since there is a price drop coming, I've decided to get the Badaxe2 and get a quad core.
My question, is there any real difference between getting a Q6600 and the Xeon x3220? I've tried searching around the forum but haven't found much info regarding this. Supposedly the Xeon is more rugged in a sense, more testing done.
Anyone have thoughts regarding this? Already got the motherboard and g.skill ram, now just waiting on the price drop.
Gtj & shimmishim any comments on this?
Trying to hit 3.6Ghz stable
vmch = 1.6 to 1.7
vfsb = tried 1.4to 1.45
vdimm = 2.2
timings = 5-5-5-15
idle temps = 51-52C
load = 68-71C
** pass/errror free memtest+86 at 400FSb (4-4-4-12 and 5-5-5-15) for 2 hrs
Please help !!!
