yeah man....with that little razor gimmick...can't messup! it can only go in so far....and the depth is exact!...:woot:
where did you get that tool from? seems handy dandy. i feel a bit more secure to pop a lid witht aht sucker then a ordinary knifeQuote:
Originally Posted by Grinch
walked into a sherwin williams paint store and by the window scrapers there it was....69cents
lol, totally owns all those guys with utility knives.Quote:
I tried alot of different tools and this is by far the easiest/foolproof way to pop lid..
Congrats Grinch & 865pe on your fantastic chips :toast:Quote:
I cant see any pictures ?????
jeeeessuss... can't even get a 0550 for 500 these days. WDF?
eGAY is being stupid
Nar still no pics, just placeholders ??????Quote:
Is anybody running their Opteron IHSless with a XP90? If this 165 doesn't do 2.7 GHz in a week of burn in, I may have to start removing body parts.
Originally Posted by alpha0ne
go under user cp...then go to edit options....scroll down to thread display options....check all 3 in visible post elements...voila
Originally Posted by r3w4
some people are but you have to modify the HSF bracket
I had mine runing lidless for a while..
I think I have a few shots lemme dig em up for ya..
I eventually gave up on the retention bracket totally and mounted bolt thrudesign and bolted str8 thru to the mobo back plate..
Cant find the pics of mounting bracket grinded, but basically it goes like this..
Take the black retention bracket holder thingiamabob, and itll have 4 little feet that will keep it almost 1/4 inch off the mobo, just take like a dremmel or somekind of grinding or cut off tool and take them about 3/4 of the way off, I took mine flat, then replace
Heres a shot of mine without any bracket at all, just using mount thru holes..
http://img.photobucket.com/albums/v5...re/clip90c.jpg
They have always been enabled ??, I'll try using FirefoxQuote:
I can also see the nice image above this post
Weird............its only this post that I cant see any images :confused: :confused: :( :mad: :slobber: :slapass:Quote:
Grinch, how do you manage not to rip the ceramic off the resistors with that paint scraper? :slobber:
Originally Posted by LiQU!D
impossible with that scraper
How do you that? More details and pics?Quote:
Originally Posted by Philosophy
I need a new dual core CPU ...but im not sure whether to get a X2 3800+ or an Opteron 165... which ones generally do better?
Opty 170 better.. good o/c and 10x multi ;)Quote:
Originally Posted by a5h
my 0550 VPMW batch#467(bought from irev210) Big Typhoon+114.7 CFM fan
room temp 25C
W/IHS ON
auto 2700mhz---loading temp43C
cpu-z 1.36v 2800mhz---loading temp46C
First results on 1.37VCore :)Quote:
Sorry image s too small
http://img143.imageshack.us/img143/7...28002vq.th.jpg
Sweet! I picked up a box cutter at my local grocery store for under a buck, plain old aluminum cutter which only reveals the tip of the razor blade, as shown behind my new opty
http://venus.walagata.com/thumbs/agunn_Poppedopty2.JPG
it worked wonders.. about 30 seconds and two passes around the chip... the depth of the blade can't reach the resistors, so cutting with confidence was much easier. :)
And how are the temps comparing with IHS on ?
