on very cold air, perhaps 5 °C
free
free
hmm I seem to be in the same boat with my 144 locks up @ 285 can run stable @ 280 ?? maybeQuote:
Originally Posted by Nights Dawn
Put in my 146 last night. Still working with it.
CABYE 0540FPMW
batch 0086
http://img498.imageshack.us/img498/1...mall0gp.th.jpg
Hi,
Please tell me if there are any absolutelly bad overclocking Opterons 146, as I can buy one for 240 USD (incl Shipping) but unknown week of production/stepping etc
please advise me should i go for it,
if its a 0542 youll see about 2.8ghz were a 0540 will do 3ghz+, theres also a 0543 & 0544 out there now but havnt seen any results yet
You got a couple of those 0542 146s didnt you tatts? Just for reference, could you list each one and what you got with it? :DQuote:
Originally Posted by tatts
Where are you guys buying the 146 right now? Newegg and zipzoomfly are out of stock on them. Does the 148 OC the same? If so, I may just get that since I can find that one in stock.
Here's my 148 CABYE0543 under water
looks like she'll be another to hit 3ghz with a volt nudge
gonna give it the cold treatment in a couple of days ....i hope she obliges.
http://img326.imageshack.us/img326/3...eron4so.th.jpg
got 0545CPBW today 148 opty.
will post results soon.
I've just received a 146 CABYE 0540APMW today. I will post results here as soon as possible, but I have to solve a problem with RAM first that makes the mobo refusing to boot anymore (it seems to be a frequent matter with DFI nF4 Ult.-D).
Anyway, before suffering of RAM problem, I was unable to post @ 3GHz, 1.6V under water... not very promising chip :(
Can you advise me which memory to use For OC these opterons, as I have a choise and a good budget, but which type and make of memory would be best??? As i have no idea
Thx
I think it depends more on your motherboard than your processor (Opteron or another one). ;)Quote:
Originally Posted by killer_pav
Which motherboard do you have?
I ma thinking of Buying DFI, Lan Party NF4 UT-D
On other forums they hit 3ghz at 1.5V(cpu-z) with WC.Quote:
Originally Posted by before
-- > killer_pav: You may wish to ask questions about DFI nF4 here
Check the link in my sig. too ;)
-- > 187(V)URD@: I really hope to obtain good results :D . Do you have links to overclockings with this stepping?
http://www.bel-hardware.be/forum/vie...hp?id=691&p=14Quote:
http://www.forumdeluxx.de/forum/showthread.php?t=171147
;) I have already seen Répliquant 67 @ bel-hardware.be;Quote:
Originally Posted by 187(V)URD@
I have to tweak my chip to see what it can really do. Actually, it is hard to believe in a strong difference between chips with the same stepping...
my 0540FPMW batch 0092 isnt doin as good as the others, needs 1.5v for 2.8 stable :(Quote:
@trans am
A friend of mine got that exact stepping the other day...just called me and told me he was stable at stock volts and 280x10...looks like he is headed over 3 for sure!
i am a foriegner, well i have a question might sounds stupid, but when you guys buy the CPU from websites as monarchcomputers, can you order a CPU with specific codes? Just tell them in the phone what code you want? who can give me an answer, thanks
Originally Posted by BMORIN
i got mine from wiredzone.com
http://www.wiredzone.com/xq/asp/ic.3...x/itemdesc.htm
No, only a handful of small shops do this. I got my CABNE that way from compumusic.Quote:
Originally Posted by AudiS4
Depending on where you are based and if you have the opportunity to travel... 146 week 0543 were in HKG as of 1 day ago... and you can see before you buy.
I called the same shop and they told me they only had one. I called 3 wks ago and had a CABYE 0540 reserved for me, but I gave it up... now I had to order it form Japan.Quote:
Originally Posted by ncsa
the AMD distributor is crap here (not the shop). the distributor didn't even know there was an dual core opty. sad.
