hehe.. well theres like 3-5mm clearance =P the beast is an
Noctua NH-U12.
thinking if i will be able to squeeze a 40mm onto the SB.
i just installed the mofset fan that cames with the MB i thought if the NB gets hot and send the heat to the mofset i will be cooled there at least.. since this cpu cooler blows sideways it wont be interfered as the stock cooler would have.. even read some warnings about it in the manual i think.
but if it wont cut it and i still get to high temps i was wondering about if i really should cut the heatpipe between the NB and mofset just to try installing
this one. And then i will have to face the cpu cooler to blow up and out through the power supply.
