Hehe I don't think I can bench anything over 1M at 3.2GHz on air but as far as screen shots go... 3.2+ is easy on this board! :toast:Quote:
Originally Posted by Rufus7
Done with 1.55v
http://valid.x86-secret.com/cache/53079.png
Done with 1.55v
Nice TMF! I am testing out a chip under phase right now and its priming at 3.2ghz at 1.48v. DogX2 sent it to me and I will max it out for him. But your 3.1ghz on air is a pretty site!:)Quote:
Originally Posted by TheMeatFrog
If my CABNE 144 was a 146, it could be the best one around. This ss was taken using a Koolance2 which is just a little bit better then my TT BT. Room temp was 23c. On any opty I have had at 1.5v I have never been able to get below 30c idle with either the TTBT or the Koolance.
http://img247.imageshack.us/img247/1...m1440kx.th.jpg
Very close to 23min mark in spi 32m calc. ;)
This opty runs an avg. 12C hotter than my 146 0536 did :eek:
http://img248.imageshack.us/img248/3...mspi4yf.th.png
Any one know what happened to the AMD Opteron Socket 939/940 * Stepping thread at forumdeluxx.de. I works only off and on and it was a very good stepping thread.
Ok, can you please tell me which kind of memory would be the best one??? (name, model) and would ddr or ddr2 be better for overclocking that opteron. And would the
CAB2E 0540 be any good for overclocking as the price on the CABYE 0540 is more than 300 USD. And also would opt 144 be any good and which model???
Thx
opty150 0528GPMW (bought from charlie)
vapoLS
dfi nf4 sli-dr
quick overclock session, didn't try to take things to the max as this is the only comp i have atm and i need it to do some work.
max cpuz screen
3.48ghz with 2x512 tccd, vcore 1.55
max occt stable, guild wars stable (if you've played the game you will know what i mean. i've had 8hour prime systems fail with guild wars)
3.1ghz, 4x512 tccd 2t. vcore 1.4
I have a question--- has anyone run a 146 1:1 at 3.2ghz
1:1 memory? Here's my CABYE 3118 MHz, x10, 1:1Quote:
Originally Posted by njkid32
http://www.cons.org/cracauer/oc-scre...uperpi1m_4.png
Nice man! Well I am at 3.15ghz at 1:1 2.5-4-3-6 but I am trying for 3.2ghz 1:1 32m stable. I have primed the chip at 3.4ghz already but I am trying to get my ram higher:)
You must have some killer TCCD to do 320. :slobber: Let's see some ss.Quote:
Hmmm.. any particular reason I havn't been reading a lot about the 17x's? I'm looking at getting an AMD system and am just trying to do the last leg of research on whether to get a 170/175 or just jump to something else alltogether like a 144/146.
I like the idea of a dual core, but I can't find any benches or anything to compare the 170-series with other AMD (and, for a laugh, Intel) options. How do they rate in comparison to, say, the other contenders like the 4400+, X2 4400+, FX-57, etc. I would really appreciate any input or links anyone can dig up.
~ Serra
You need to go here:http://www.xtremesystems.org/forums/...ad.php?t=77857Quote:
Originally Posted by Serra
A w e s o m e !
He Meatfrog a Friend of me did hit the 3,4Gig on Air or 3,5Gig with an Sonic Tower at low Ambienttemps.Quote:
I don´t know if he has any Screens. But he showed me one Screen, taken with a Digicam. Have to search for it.
Even if it was a 146 it would still be quite a good one if you ask me :) :thumbsup:Quote:
Originally Posted by dogsx2
Heres a few quick n dirty Pi shots with my new 146 :)
http://i16.photobucket.com/albums/b2...ne/32M3088.jpg
http://i16.photobucket.com/albums/b2...0ne/1M3133.jpg
:D
Looks like you got a good one. I've seen some with a X in the stepping and wondered if they were any good, looks like they are.Quote:
Originally Posted by alpha0ne
I agree, Guild wars replaced NFS underground as my stability test program : It fails within minutes while Prime can be stable 8+ hours. Definitely a good way to spare a lot of time...Quote:
Originally Posted by jikdoc
Here is my 146 CABYE on water cooling and a crummy ole MSI Neo2 plat. On my DFI SLI DR I know it will get better. Im pretty sure i can hit 3.1 to 3.2 and do it stable. This was all i could do for now. More to come!!!
http://i13.photobucket.com/albums/a2...3o/Opt1461.jpg
If you can use most wanted for stability than what happens to me ? I can game a few hours, never tested more :) but prime blend failes instantly with a reboot and/or bsod.
i have a weird problem. i can run 300 x 9 at 1.3v with memory at 1:1. Also, i can run 290 x 10 at 1.344v (cpu-z) for some time, sometimes reboots (messing around with mem. timings should fix this). BUT, when i trie to boot up / prime at 280 x 10, my system boots to windows, then EITHER reboots instantly, OR primes for a couple of minutes, than reboots.
I'm using bios 623-3 and have all options set to defaults, except 2.5-4-3-7. Could Max. Async or Read Preamble settings cause this? (Because they're set to AUTO). Also, could it be that the DFI SLI-DR uses different settings for let's say 250-290FSB and 290+ when set to AUTO? Should i set them manually?
tnx!
thats the best CPU of 7 0540FPBWs
146 0540 FPBW 0203er Batch
still with Heatspreader. ill cut the IHS next weak.
3180MHz@1,56V watercooled
http://mitglied.lycos.de/freestylerc...0MHz@1,56V.JPG
free
The best fpbw i have seen :fact:Quote:
Originally Posted by freestylercs
Batch 200-240 looks good on fpbw
Hi Meatfrog here are the promised screens from an Opteron 146 0540FPBW on Air with an Sonic tower.
Look what he made.His name is Microborg and he is at hardwareluxx in the Forum.
http://www.bilder-hosting.de/uploads/0a4bca7b4f.jpg
http://www.bilder-hosting.de/uploads/df70a99794.jpg
And now a few Suicides on Air taken with a Digicam.Abmbient was very cold below 10°C.lol
http://www.bilder-hosting.de/uploads/039bbc9231.jpg
http://www.bilder-hosting.de/uploads/48e9fa4433.jpg
