I just installed my X-FI card yesterday, it works in the top slot , zero issues with it so far an I'm on Vista.
I did originally have the Asus card in first
Try using an older version (v6...) of AsusUpdate while @ stock clocks.
I know I know, AsusUpdate sucks, but in this case, it seems to be the best solution.
Just make sure you minimise the chances of it locking or crashing by running EVERYTHING @ stock!
Owki IŽll give it a try.
I also downloaded afudos 2.11, 2.17, 2.19, 2.21 to check if any of those work.
What settings?
I run my RAM (4x1GB - 2GB OCZ Reaper DDR2 1066 and 2GB Ballistix DDR2 1066) at 600 (DDR2 1200) 5-5-5-15-2T @ 2.25 volts no problem. Had to bump my NB volts from 1.57 to 1.62 to get it stable, but it works fine. OCCT beta is fricken awesome for testing the NB - RAM connection.
thanks for the info. are you noticing any performance increases with ram at 600MHz over, lets say 300-400MHZ?
has anyone here used the software the board came with ? Is the power button on the board handy ?
The power button is very handy. If however it feels like it's not working, hold it down or put a little more pressure than you'd normally require and it'll work. I think it's like a safety feature to not knock it and power on/off.
I just tried to install AsusUpdate v6.xxxx on Vista64 but it couldnt install it.
I hate to say this but i think Im stuck with this crap bios for now :)
:shocked: :shocked: :shocked:
http://img402.imageshack.us/img402/2...deerrorzp3.png
Despite me ranting that my Prelude is working fine in the top PCI slot, this has happened while I have been out at work today. I have no clue to why or how but its now not working. I haven't done anything different!
WTF!!!!!!
I found this link for the flash archive:
ftp://ftp.asus.com.tw/pub/ASUS/mb/flash/
I have 6.0 beta if you want to try it
I can up it to fileshare or something or I can load it on my ftp
Is it a bios setting or what are you guys doing different to get sound card working in top slot ?
i didn't install the asus sound card, so do i have to disable anything apart from onboard sound in bios ?
I'm behind a router so enable /disable pasv
Here is a link to Asus Update 6.0 Beta
http://fileho.com/download/2aee33301...sUpdt.rar.html
