What are the coolers you got for your RAM sticks?
@Lamb: The coolers for the rams are Thermalright HR 07:
http://www.abload.de/img/img_0260ctz.jpg
@Markicks: Okay:)
I really, really like em! Looks much better than my OCZ XTC Mem. Cooler! (my opinion) Which would be better, high or short rise? ( There's 2 different models) I guess short ones would be better since they would not be blocking my CPU Heatsink airflow (soon to be 133CFM...lol) as the high rise ones would, can you comment on that? :am:
Short:
http://www.acousticpc.com/images/a_t...uo_type_l2.jpg
High:
http://specialtech.co.uk/spshop/file...r-07-duo-h.gif
The advantage of the short rise is that they fit nearly with every cpu cooler but the high rise are cooling the rams a little bit better, beacause they are on the same height like the cpu fan.
if you have 4 ram modules you can take a pair of the high an a pair of the short ones.
btw, i don't know the 133CFM. do you have a picture?
By 133 CFM's I mean the airflow of my future fans ;P
Putting 1 or 2 Scythe Ultra Kaze 3000RPM fan on my IFX-14 when I'll upgrade my rig! 6 of these total in the case, will get great airlfow ^.^
(3000rpm ones!)
http://www.overclock3d.net/gfx/artic...135429998l.jpg
So, high rise would be better, thanks!
Hey guys, i need help..
I will buy a cooler for my cpu..i want to put 2 cooler in the heatsink..one launching air to heatsink, and other, on the other side of heatsink, pushing the hot air to the fan case...but my case accepts only 92mm cooler, and i will put a 120mm coolers in the heatsink..
i think the fan of the case will not have capacity to grab the hot air to out of case...
can anyone help me to make a cooling system acceptable to put my cpu to 3.8ghz??
I made a sketch in the paint...hahahaha
I hope you understand :D
Sorry if I posted in the wrong area
Nanoxia CX12 ThreeSixty Prototype :)
http://www.abload.de/img/dfi004wko.jpg
http://www.abload.de/img/dfi005j62.jpg
What about the ram coolers?
those ram coolers are sick!!
Is this the way the cooler is supposed to be installed in a case also or do you have to turn it to vertical/horizontal again?
//edit: RAM coolers look nice, but I've seen better like those from mcp. Just taste of what you like... ;)
The cooler can be turned 360 degrees. In this position i gain the best result.
My Case and Airflow 'way through'
http://www.abload.de/img/meinpc0049sn.jpg
I love black cooler on my board, cpu and RAM.
I'd the Thermalright lineup in my last system, time to change. ;)
http://patrock84.de/gfx/meinpc/2007.08/002__.jpg
@ patrock84
The first picture of your post is about my question??
If i'm corret, with this position of cooler, the psu will not be hot??
The PSU is at the bottom of my case.
Ich hope you better understand, what i mean, when you look at this drawing/sketch:
http://www.abload.de/img/blubbc7i.jpg
blue= cold air
ret= hot air
Yep...
but my psu is at the top of the case :(
I should post a picture of my Antec P180 Mini case. Simple but effective.
wow patrock.
NANOXIA - CLOSED
nanoxia will be discontinued.
The ex european distributor xen micro GmbH registered the trademark nanoxia against all aggrements on their own name.
All products wich will come with the nanoxia trademark on the market will not be original "nanoxia" products.
the original founder and engineer behind nanoxia - May 08
Nate P do you have any more up close pics ?
nice setup patrock!:up: didn't know you could orient the cpu cooler that way. which Xigmatek cooler is that? by the way, you ram sinks looks like what Arctic Cooling is about to release...
http://www.arctic-cooling.com/pics/products/160_big.jpg
apparently with some new ram coolers too..
http://www.arctic-cooling.com/pics/products/165_big.jpg
The background colour brings it all together really well
Its amazing what construction paper will do, curious though i still cant get my images to look as crystal clear as that :/
