That makes perfect sense - sorry I didn't pick it up the first time.
i'll try that out t'night - thank you for taking the time to explain, I gues I just didn't completley understand what you were trying to say the first time around.
Are there any specific settings Imight want to work with (DRam voltage, etc) when I try to make that change I get boot failure fron windows and frequent BIOS lockup before POST completes, it was hard just to get back in and change it back before it locked up - really didn't want to have to redo all the tweaking (havn't been great about saving it as I go - changed that now of course)
Thanks for all you guys help
EDIT - on a separate note - I seem to be performing very well and Prime Stable for at least 30 minutes (yeah I know its not like 2 hours or 24 hours as some like to run - but I stopped it when thermals on one of the core's crept up to 74C, am I being a little over protective of my chip or do I need to look for ways to improve my thermals before continuing to attempt longer prime runs?
What ram kit are you using? If your only at 1.6 vdimm now you may need to bump it up some. As for your temps I wouldnt worry about them to much at this point as long as they dont go much higher during prime.
Do you still have your mch voltage set to auto? If yes than set it to 1.32v and also disable xmp.
sweet thanks! I'll give that a shot...I got my thermals way down finally - in the middle of a prime run at only 63C right now...which is much better (new grease, new fan, and needed to turn one of my intakes into an exsaust since my rear exsaust became an intake (for the Corsair radiator)
I'm hoping this will run for at least 2 hours, then I'm off to play with the ram again...
My new batch
vid 1.1875v
http://img338.imageshack.us/img338/9...3524552935.jpg
Sweeeeet what's the batch #
on the screen
batch #L004B845 packdate 04/09/10
dam its nice to see they are making nice chips in 2010, thats loads better than my Xeon.
very nice pvhk
Great VID but Super Pi = Piece Of Cake.
Give us some Linpack / Prime95 Blend screens.
1.2VID
http://img188.imageshack.us/img188/1...voltage.th.jpg
http://img706.imageshack.us/img706/9...oltagey.th.jpg
impressive fsb form x38 mb, how much vNB u use ?:P
my other q9650 vid 1.2375v (1.10v=wrong value)
on DFI UT P45
http://img100.imageshack.us/img100/7...2662436259.jpg
http://img697.imageshack.us/img697/9...5963996.th.jpg
Yeap - the RAM sucks, or I suck, and since I'm not willing to face the reality that it is me, it must be the RAM, I just can't squeeze any more performance out of it...on the other hand, I finally confirmed I'm 24hr Prime stable and incrementally lowerd my Voltages to 1.2875, thermals are much better - never above 69c and generally average 60-64c. (loaded) and idle around 39c
http://i209.photobucket.com/albums/b...sadler/ram.png
Code:GIGABYTE GA-EP45T_USB3P
[u]MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: AUTO
CPU Clock Ratio ..........................: 9X
Fine CPU Clock Ratio.....................:0.0
CPU Frequency ...........................: 4.05GHz GHz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled] []
CPU Host Frequency (Mhz) ............:450Mhz
PCI Express Frequency (Mhz) .........:100Mhz
C.I.A. 2.............................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................:800mv
PCI Express Clock Drive...................:900mv
CPU Clock Skew (ps).......................: 0ps
MCH Clock Skew (ps).......................: 0ps
DRAM Performance Control
Performance Enhance....................: [Standard]
Extreme Memory Profile (X.M.P.)........: DISABLED
(G)MCH Frequency Latch.................: [Auto]
System Memory Multiplier ..............:3.33D
Memory Frequency (Mhz) ..............: 1500Mhz
DRAM Timing Selectable ................: [Manual] []
Standard Timing Control
CAS Latency Time...............................: 8
tRCD ..........................................: 8
tRP...........................................: 8
tRAS...........................................: 24
Advanced Timing Control [Press Enter]
tRRD...........................................:AUTO
tWTR...........................................: AUTO
tWR............................................: AUTO
tRFC...........................................: AUTO
tRTP...........................................: AUTO
Command Rate (CMD) ............................: AUTO
Channel A
Channel A Timings Settings [Press Enter]
Static tRead Value......................:Auto
tRD Phase0 Adjustment...................:Auto
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)..................:Auto
Twr2wr(Different Rank)..................:Auto
Twr2rd(Different Rank)..................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control................:Auto ps
Dimm2 Clock Skew Control................:Auto ps
Channel A Driving Settings [Press Enter]
Driving Strength Profile:[AUTO]
Data Driving Pull-Up Level.............:Auto
Cmd Driving Pull-Up Level..............:Auto
Ctrl Driving Pull-Up Level.............:Auto
Clk Driving Pull-Up Level..............:Auto
Data Driving Pull-Down Level...........:Auto
Cmd Driving Pull-Down Level............:Auto
Ctrl Driving Pull-Down Level...........:Auto
Clk Driving Pull-Down Level............:Auto
Channel B
Channel B Timings Settings [Press Enter]
tRD Phase0 Adjustmen...................:Auto
Channel B Driving Settings [Press Enter]
{U]Motherboard Voltage Control{/U]
CPU Vcore . ...........................:1.28750v
CPU Termination ...... 1.200V*...........: 1.2000v
CPU PLL .........1.500V*...........: 1.5000v
CPU Reference............................: .760
MCH/ICH
MCH Core ..........1.100V............:1.32
MCH Reference.. ... . .0.800V............; .800
ICH I/O .... ......1.550V............: AUTO
DRAM
DRAM Voltage ........1.500V............:1.34
DRAM Termination ... ..0.900V............: AUTO
Channel A Data Vref ...0.75V.............: AUTO
Channel B Data Vref ...0.750V............: AUTO
Channel A Address Vref 0.75V.............: AUTO
Channel B Address Vref 0.750V............: AUTO
[b]{U]Advanced Settings[b]{U]
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [DISABLED]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled]
Note: * refers to 45nm CPU
b1t, put 50 on your MCH skew, and raise your CPU termination, you will get a lot farther.
Hi! I just got my new Q9650 CPU ! I am using it on an asus maximus extreme x38 mobo! Right now it is OC to 3.6GHZ and cpu is quiet happy and cool!
here is my retail cpu information:
Pack date: 5/3/2010
FPO/Batch: L009B453
S-spec: SLB8W
VID: 1.2250v
http://img190.imageshack.us/img190/4658/64944802.png
http://img594.imageshack.us/img594/5329/sdc11149.jpg
