every CPU is different.............some go up to -90CQuote:
yeah ok, so the MACH II isn´t necessary a good investment? Hope it doesn´t bugs out before -50C
it is a good investment but depends if youre lucky with the cpu, most people i spoke to said theres started @ -20C and knowing my luck id have the same problem and dont fancy putting high volts through to try and raise temps, the only way youll know is by trying it, you may have a better cpu?
So, i can´t just adjust the MACH II to a temperature about 0C so it doesn´t cold bug`?
Mine seemed to work just fine. I made sure that I didn't tighten my waterblock to tight. Now that the AS5 has settled in my temps are slightly lower. Right now Room temp is 20C and load temp on water is 34C @ 2.8GHz CABYE 0536 1.55vQuote:
Originally Posted by 187(V)URD@
No it´s only oldfashioned, cause i´m over 40years Old. Only Computer is futuristic.lol. I´m living in Germany.Quote:
Originally Posted by KoHaN69
He Loki2k what did you did to that mega Chip you did kill it?
Try it on the Board must not be killed. I have friends who killed also the little Bugs on the core one of them and the Chip is working. Good working.
And that must be 99% stable.Heres the Screen.
http://www.bilder-hosting.de/uploads/e0978fd008.jpg
Got some Opteron 146 luvin this morning. :)
3x CABYE 0542FPMW
It seems I have missplaced the third one, hopefully I'll find it... :slap:
First one with very little effort:
4 hours of SP2004 with "large":
http://www.helsinki.fi/~llounent/Opteron_2.jpg
Didn't remember to take a cap of the SP2004 run. :(
To be continued.
Mayday, mayday, mayday.
I have a huge problem and it makes me nuts.
I changed from E3 venice to opteron 146 and when i booted to windows the comp booted itself after awhile. So i installed all drivers again hoping it would solve everything. Nothing changed.
Then i installed a fresh windows. Now when i started a web browser AN INSTANT REBOOT. It does this with IE and Mozilla Firefox. I have tried 623-3 and 7xx bioses and its no go :(
This makes me mad mad mad mad mad.
Edit: mayday cancelled. After trying everything i tried another lan port and everything works fine. Damn im stupid :slap:
Check mem stability, can you pass 32M SuperPi with Opteron?Quote:
Originally Posted by Sume4
Raise your read preamble by 0.5
I havent had the time to even test the opteron yet. Hopefully i hit 3Ghz+ with Air cooling :banana: CABYE0540FPBW it is. :)Quote:
Originally Posted by need.for.mhz
What lanport do you use now?Quote:
I´m using the 623-3 Bios and it works fine with an Opteron 170 DC.
And im using the Lanport high above must be the first. I had never Problems with the Lanports and Opterons.
http://www.bilder-hosting.de/uploads/99af913271.jpg
Yep im using the same marvell lan port now and it works fine.Quote:
Originally Posted by Rufus7
i popped in the opty 150. cant pass prime after ~2.7GHZ. same deal with my SD core. SPI32M passes well after that. i will try this LAN port thang, as well as disabling everything and trying again.
you guys think i should raise my +12 rail? doesn't appear low, but two cpu's, similar 'prime95' limit. doesn't make any sense.
also noticed that dual channel with my classic BH5 is iffy. will get no boot when both sticks in initially (after CCMOS clear, etc.). the only way i can do it is if i pop one stick in top orange, boot up, shutdown, stick the second stick in lower orange, and then itll boot up.
similar deal with the UTT BH.
the CH5 doesnt appear to exhibit this issue.
tested on fxtest60. things appear slightly better on 704-2bt, but it is still there (the 'wierdness').
any thoughts?
Did u try yellow slots?
Good luck, I got the same stepping. 3Ghz should be attainable but probably with nuclear reactor :p:Quote:
I havent had the time to even test the opteron yet. Hopefully i hit 3Ghz+ with Air cooling CABYE0540FPBW it is.
http://www.xtremesystems.org/forums/...id=40372&stc=1
Will Prime until 2.94Ghz for 30min, then 1.504v for 2.95~2.97Ghz. And then I get killed by temps. IHS removed, hetasink lapped mirror-like finish and as5 was used. Venus12 Cooler at 6000rpm and I get 53C Load with 1.504v
This cpu should prime at 1.6v@3000Mhz, but guess what happened when I tried that?. 34C idle, fired up Prime then after 1 sec. 44C, after 2 sec. 54C (I thought this ain't good), after 3 sec. 61C :shocked: and then after every 2 sec. it went 1C up until 65C and then I stopped Priming.
So now I run 2.9Ghz at 1.392v, btw my CABYE 0536GPMW ran at avg. 10C cooler at same speeds with same setup. No worry though, Big Typhoon + 151cfm delta is coming soon ;)
yea.. same deal.Quote:
Originally Posted by Shark-357
this sucks...i'm sitting here looking at my Opteron CABYE 0540 FPBW....and i can't even use it..it sucks being poor and not having the money to buy ALL the parts right away :( and the Asus A8N32-SLI is expensive...but the DFI Ultra-D is only 113 right now at the egg..
what do you guys think...Ultra D or save up for A8N32-SLI ?
I can buy any mb I want but I just bought another Ultra-d. They clock high HTT and the bios is very mature. The last 2 U-D's have both clocked 380+HTT with an 8x.Quote:
Originally Posted by Raven.exe
3Ghz with 1,55vcore and zalman cnps9500 cu led seems to work fine.
I used Abit for as long time. Since the Intel Celery 300 that overclocked to 500.... rememver them suckers.. I changed this year to DFI NF4 Ultra D just because of the hype..... I will never go back... Get the DFI
Best mobo I ever had and all of them where Abit and a few Asus. I also built a lot of machine using MSI and other..
DFI is the way to go.. :banana:
Asus A8R-MVP should be everywhere next week, seems like a nice mobo with a nice price tag.Quote:
You crazy?!? :slap: Sell that cpu till you find one that boots.Quote:
Originally Posted by Wiker
You better do some reading before you hook that thing up. The last thing you want is to fry your new system. Good luck.
Has anyone been buying any 150s from anywhere in the US? I'm looking to get one from the egg.. guessing they still might be old since not a lot of people are buying them and they are a little overprice compared to other retailers.
alright guys ive been checking out ebay...which one of these would be the best for my money: all 146s
CABYE 0536 GPMW
CAB2E 0540FPMW
CABYE 0540FPBW
or would i just be better off getting a retail 148 from newegg?
CABYE 0540 FPBW....would be your best bet...
and i just ordered an Ultra-D...i'll get the Asus when they go over to m2...yay..i now for everything else...it will be awhile.
