Originally Posted by
mazda_626
here is my current settings and complaints before the bios change, please refrain from any comments on bad settings, I want to see if my current knowledge and the new rampage bios proves to make things better:)
Im currently still using the MF907 beta bios (most of the MF bios' appear to be beta :rolleyes: )
I hate this board with a vengence, i went from a DFI expert to this, problem is i expected things to go just as smoothly as the DFI board, my mistake :)
currently my mobo is only stable when O/C'd and with the two different types of ram, which is confusing to me but meh.
currently room temp is warm, about 28-30c (estimate), mobo temp is 38c, cpu idle is 45c, cpu load is 65c. all according to Speedfan, coretemp shows idle as 42,39,33,32c so all is normalish.
I use every fan port possible with success in viarable fan speeds.
I've only had this mobo since mid December, played with it for a month and found it likes all the ram modules, remove either kit and the o/c drops :confused: drop the multi and the FSB wont go up without alot of voltages.
in reality, this is probably due to the amount of HDD's, heat and the ram along with my noobness. but i tried many things and just cant get over 400FSB with the current setup and bios.
I also cant restart the computer without hitting the reset switch. it will shut down and restart but on OS hand over, it just has a blank screens, hit the reset switch and when the OS sarts, it ask if i want to boot into safe mode. only ever happens when i restart from OS, restart from bios is fine. could be a raid 0 bug.
occasionally the system will hang at the bios post screen, so i uploaded a pic i like to look at just to ease the pain, then hit the reset switch.
with probe 2 installed, i get a bios warning stsating the SB is too hot, this can be from cold boot
currently rock solid stable and here are the settings
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : AUTO
(- Ratio CMOS Setting : 9)
FSB Frequency : 378
FSB Strap to North Bridge : AUTO
PCI-E Frequency: 100
DRAM Frequency: DDR2- 1007
DRAM Command Rate : T2
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : A
Row Refresh Cycle Time : A
Write Recovery Time : A
Read to Precharge Time : A
Read to Write Delay (S/D) : A
Write to Read Delay (S) : A
Write to Read Delay (D) : A
Read to Read Delay (S) : A
Read to Read Delay (D) : A
Write to Write Delay (S) : A
Write to Write Delay (D) : A
DRAM Static Read Control: A
Ai Clock Twister : A
Transaction Booster : A
CPU Voltage : 1.1.45
CPU PLL Voltage : 1.58
North Bridge Voltage : 1.51
DRAM Voltage : 2
FSB Termination Voltage : 1.42
South Bridge Voltage : 1.05
Loadline Calibration : E
CPU GTL Reference : 0.63
North Bridge GTL Reference : 0.67
DDR2 Channel A REF Voltage : A
DDR2 Channel B REF Voltage : A
DDR2 Controller REF Voltage : A
SB 1.5V Voltage : 1.5
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED :
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
I shall now hunt down the everest download (page 2 i think) and post some scores. anything else people want before i move to the rampage bios?
I suppose i cant say i hate this mobo, it is a challenge to get stable but atleast it's easir to work with than the gigabyte DQ6 or so I've heard.:rolleyes:
Before i do spam the thread with everst and temp pics, along with 3Dmark scores, I'll make a dual boot of XP, then i will use the same OS with the new bios, just to keep things constant.
So it will take a few days, thought some people waiting for results may wish to know :)
