here is my one:Quote:
Originally Posted by Rufus7
http://mitglied.lycos.de/meinnamegeh...65v%20pi1m.JPG
with aircooling on abit an8 ultra.
An Excellent result there loc.o :woot:Quote:
Originally Posted by loc.o
Have tried the Multi Processor HAL but made no difference for me ... have now seen other FPAWs running DDR600 so must be this particualr IMC or MB combination .. going to move Chip to another MB just to see if this is the case.
A freshly installed WInXP does make the difference......, same setup as previous post:
CABYE 0540FPMW+DFI Ultra-D+Geil One SE 2x512MB.
http://members.shaw.ca/tsopin/1123053.jpg
:p:
Will try 10x310 these days, hopefully, to finish the test for PI 32M.
146 CABYE FPBW under watercooling
ambiant temp ~ 17° , full CPU Temp ~33°
http://users.skynet.be/pt1t/146/146_3005_1.40v_occt.PNG
http://users.skynet.be/pt1t/146/146_3005_1.40v_temp.PNG
http://users.skynet.be/pt1t/146/146_....40v_vcore.PNG
loc.o: Great result and good job :)
Stepping?
Mach II with recharged gas/modded?
What's the ricky tweak?
Monge :toast:
CABYE 0540 FPMW. Stock mach. The tweak is using acpi multiprocessor in device manager. It increases idle temps (and helps a little for a 2k1 score).
just recieved my CABYE 0540 APMW. The bad thing is i have to leave for 2 days :p
Just received a retail 148 0540 FPBW from Newegg, doesn't seem to like 3gigs. All fine and stable at 2.95 1.5v but thats about it as far as stability goes. :(
quick setting to 3ghz, i'll test more when i am back home on saterday.Quote:
Originally Posted by 187(V)URD@
Hi. My Opteron 146 0540FPBW running 3,2 ghz on water.
Link in the sig
Greets
Just wondering what your TMax case on your FPBW? Seems most 146 with this stepping are out performing the 148's with same stepping and week.Quote:
Originally Posted by phreakymind
yes ive encountered the same thing. most 148 0540 dont go that high on water. gonna test the max later and post some results.Quote:
Originally Posted by RacerX
Same of mineQuote:
SPI 1M http://users.skynet.be/pt1t/146/3224_1m.PNG
CPUMARK http://users.skynet.be/pt1t/146/cpumark_432.PNG
maxTcase is 63° with 5 ° offset.
Well mine is doing 10x326 SuperPi 1M stable. no big difference there: *click*
Nice Chip you have V187.Quote:
For a quick setting very good.
Keep on clocking!
And thats the 170 DC Opteron i have since Saturday Night under Water.
http://www.bilder-hosting.de/uploads/e34fdfdcb5.jpg
And Prime is still running since 11Hours until tommorrow Morning wanna get the 24H Screen for stability.
Thats a nice 170 you have there Rufus7 running @ default Vcore :toast:
Check out my new 146 CABYE 0543FPMW running @ default Vcore :)
http://i16.photobucket.com/albums/b29/alpha0ne/32M2.jpg
:D :D
Alphaone it must be an CABY 0542FPMW. 0543 i´ve never seen before. Or is it a new Productionweek?Nice clocks on Water. Put on your PWM and Mosfets en 120mm Fan above and your PWM Temperature will fall down.
Yer already organised for another fan over the fets
the stepping is correct :)
a test @ 2.8ghzQuote:
Originally Posted by Pt1t
http://users.skynet.be/pt1t/146/146_2800_1.28v_occt.PNG
http://users.skynet.be/pt1t/146/146_....28v_vcore.PNG
http://users.skynet.be/pt1t/146/146_2800_1.28v_temp.PNG
Just received my Opteron 148 from NCIX in Canada..
'CABYE 0543FPMW'
I hope I will be able to obtain similar results to your 146 '0543' alpha0ne..
[QUOTE=Pt1t]a test @ 2.8ghz
Pt1t what kind of cooling you got?
It says "water" further up ;)Quote:
Originally Posted by dogsx2
CABYE 0543FPMW
So far, I'm very impressed with my Opteron 148.. $297CDN FX-57.. Haven't even touched the vcore yet, and I haven't hit the max at default vcore either..
Cooling is retail XP90 w/stock fan..
More results to come..
http://www.xtremesystems.org/forums/...chmentid=40347
