my old Q9650 VID 1.25
http://www.hostanyimage.com/files/46...9508849652.png
that was not prime stable, just 2D stable. I was able to run superpi 1M and thats all I really tried. It was on air as well, lapped TRUE with a single San Ace 109R, definitely too hot to prime or burntest.
here is my new Q9650, VID 1.1875
http://www.hostanyimage.com/files/45...2546211382.png
it does well at low volts but anything more than that will burst into flames:shocked:
I am deciding on what parts I want for my loop, and I am thinking EK Supreme HF, dual DDC with XSPC dual top, 7/16" ID tubing with 1/2 fittings of some sort (bitspower), GTX 240 radiator to fit inside my CM690.
Can anyone suggest some quality fittings?
