Attach and insert asus CD or floppy (with autoexec.bat doing bios flash) and see if it starts reading it :)
Well i am running them at 890MHz and not 1066MHz like they are supposed to run so i lowered the voltage.
Also isnt 1:1 ratio faster than anything else ?
not work.. i think the boot sector already dead too....
Thanks for the reply, XtremeTiramisu!:)
Well, I got the RF bios to run my previous MF bios setting of 8x450 fsb with ram timings and ram related settings set on auto. However, I noticed vCore and NB volts needed more juice than it did before when I was still using the MF bios. I think I'm gonna switch back to MF for the sake of lower voltage settings.
I wanna get this right in terms of flashing back to MF.
C:\>AFU236U /MF0907.rom /pbnc /n
Am I right?
C:\>AFU236U /iMF0907.rom /pbnc /n
You need the "i" in front of the mf0907.rom
also what's all this /pbnc business? I just use /n and it works fine for me.
This is my stable setting:
All sub timing set to auto
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : Auto
CPU Ratio Setting : 9
FSB Frequency : 455
PCIE Frequency : 110
DRAM Frequency : DDR2-1093
DRAM Command Rate : 2N
DRAM CLK Skew on Channel A : Auto
DRAM CLK Skew on Channel B : Auto
DRAM Timing Control : Manual
Cas# Latency : 5
Ras# to Cas# Delay : 5
Ras# Pre Time : 5
Ras# Act Time : 15
DRAM Stactic Read Control : Auto
Ai Clock Twister : Stronger
Ai Transaction Booster : Manual
Common Performance Level : 07
Pull-In of CHA : (all Disabled)
CPU Voltage : 1.387
CPU PLL Voltage : Auto
North Bridge Voltage : 1.51
DRAM Voltage : 2.20
FSB Termination Voltage : 1.44
South Bridge Voltage : 1.050
SB 1.5V Voltage : 1.50
CPU GTL Voltage Reference : 0.63x
NB GTL Voltage Reference : 0.67x
DRAM Controller Voltage REF : DDR2_REF
DRAM Channel A Voltage REF : Auto
DRAM Channel B Voltage REF : Auto
CPU Spread Spectrum : Auto
PCIE Spread Spectrum : Auto
Hey Gurusan, I tried your method and Extremetiramisu's method and I can't flash back to MF bios.
I typed the exact same thing as you did: c:\> AFU236U /iMF0907.rom /pbnc /n
or just /n
And I keep getting an error that says:
Error: Rom file ROMID is not compatible with existing BIOS ROMID.
*edit
Never mind...I got it to work. I didn't know you weren't supposed to delete the RF bios from the USB memory stick. Whelp, I'm back to Maximus Formula bios! Home sweet home!
And Gurusan was right, you don't have to type /pbnc--just /n will do! Thanks Extreme and Gurusan for the responses and help! :)
I never try using the white slots
Actually it has in almost every case..The differences are too small indeed but if i am not to gain nothing why change it ?
And i have never tried the blue ones lol!
I was playing with FSB (water had 4-5C:D ):
http://shrani.si/t/1A/xn/2i8Vm9pA/fsb-532mhz.jpg
But it is quite interesting, that if I set mother board voltages too high, I can't past even 500mhz.
What are your settings for benching?
Afcourse not! (that would be extremely pathetic:eek: This voltage vas only for further overclocking (4500 super PI, on water- afcourse I've used higher voltage for that)
It needs 1.57 (bios) for Prime95 small FFT stable at 4ghz:D
Nice fsb for a Q6600:up:.....it is obvious he was aiming for FSB and i think those volts could backed a few notches tho.
ah thanks for that!
On a further note, I've just reached 467fsb with my P5E running rampage 219 bios.
http://img212.imageshack.us/img212/1...chemem2of3.png
not bad for a 110 quid shipped board :)
very nice !
now is it stable?
The prodical son returns hahaha
how r u my friend?
:up:
bahh it crashed right after I wrote that....just set it back to my previous stable of 462mhz which still isn't so bad. I've had enough messing around for the night....Got a craving for some CoD4 now :)
hiya m8 , I am fine:D come msn if u r there:)
need some help:
Q6600 G0 (consider it STANDART batch) at 3.6ghz, 450x8 (trying 3.8ghz stalble 24/7)
maximus formula BIOS 505
4x1gb Crucial Ballistix 1066mhz, Brand new, still in sealed box :D)
it's one-sided memo's
hope my X38 don't kill them...................:(
wich timings, Vdimm, and AUTO things should I do?
just need some @1100-1150mhz stable
should I try multi X9 on cpu? wich would sound better?
Extreme Tweaker
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 8
FSB Frequency : 450
FSB Strap to North Bridge : 400
PCI-E Frequency: 101
DRAM Frequency: DDR2- XXXX?
DRAM Command Rate : XX?
DRAM Timing Control: Manual
CAS# Latency : XX?
RAS# to CAS# Delay : XX?
RAS# Precharge : XX?
RAS# ActivateTime : XX?
RAS# to RAS# Delay : XX?
Row Refresh Cycle Time : XX?
Write Recovery Time : XX?
Read to Precharge Time : XX?
Read to Write Delay (S/D) : XX?
Write to Read Delay (S) : XX?
Write to Read Delay (D) : XX?
Read to Read Delay (S) : XX?
Read to Read Delay (D) : XX?
Write to Write Delay (S) : XX?
Write to Write Delay (D) : XX?
DRAM Static Read Control: XX?
Ai Clock Twister : WIch would be better for 4x1gb pc8500 Ballistix?????
Transaction Booster : Enabled (0) is this right??
CPU Voltage : 1.5 Good?
North Bridge Voltage : 1.5 good?
DRAM Voltage : XXX?
FSB Termination Voltage : AUTO
South Bridge Voltage : AUTO
Loadline Calibration : Enabled good?
CPU GTL Reference : AUTO
North Bridge GTL Reference : AUTO
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : AUTO
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : Enabled
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Disabled
Gurusan, You are going to want to reflash the RF BIOS. Your still showing as a P5E on your mem bench. It should say Formula Rampage. You probably didn't flash with all the correct switches to do the NVRam and bootblock which is probably what it being used to detect the MB. It might also maybe help get it stable as well, but I don't know on that front.
