One of the Northbridge hooks came off *HELP*
Hi all,
So as I mentioned before, I went through and purchased a Thermaltake Extreme 2 Northbridge cooler (copper block with integrated 40mm fan) and installed it on my board this past weekend. Everything was functioning fine until last night, when somehow one of the two clips holding the northbridge into the motherboard came off. I only noticed it when I looked in my case trying to figure out why my computer was crashing almost immediately after windows booted up.
I haven't cleaned the arctic silver off the northbridge yet to see if the chip is completely hosed, but I don't believe it is, since it is able to boot into windows before crashing (overheating?). However, I'm concerned because the hook came off and I'm unable to mount anything with only one hook.
I did take a photograph of the northbridge, and thankfully the hook that came off is in the clip 3 position, at the bottomright part of the board (next to the ram), which is only a mm or two from the existing screw. This makes it possible to engineer another solution, which I will look into as well.
I wanted to know a couple of things though:
1) Do the northbridge mounting holes go through all layers of PCB to the other end of the motherboard?
2) What is "anchoring" the hooks in place currently? I tried to do some elementary research on other, third-party, northbridge cooling products, and all seem to use the existing hooks, none explaining what to do in the dire case of one coming off.
3) If the hook that came off ends up being lost, does anyone know how I can acquire a new one, outside of manufacturing my own? I guess this is only applicable if the board is capable of modification to re-insert the hook.
Please advise.
