0550 UPMW <- has really good and really bad CPUs
0550 VPMW <- best
0546 XPMW <- get 2.85-2.9 average
0530 TPMW <- not quite sure what to tell ya here, was the favorite before the 0550's
0550 VPMW <- best
THX, Clint, Im going to see, how this 170 s gonna go,Quote:
Originally Posted by Clint
do hope, that it ll be a little bit better than 0551 UPMW ;)
yes, and may the Force be with us all .... :)
Originally Posted by CompGeek
seen this on ebay :
http://cgi.ebay.com/NEW-AMD-Opteron-...QQcmdZViewItem
0546 XPMW :)
and the seller is really good
DONT buy there!
Buy from dave, he has 2x @ $430 shipped.
flickerdown.com
Anyone Here using ballistix ??
I got A Opteron 165 but i think it hates my memory. Cpu douse 2.6 @ 1.35v not a verry good one. Because it will not to 2.650 @ 1.35 and its ramping voltage after that. Maxed out @ 2700 1.52v.
Maybe i should get a new 4400+ VPMW. Opterons dont go well with me A8R32-MVP. Max v-core is 1.55 with opterons. A64 X2 can get up to 1.65.
That 165 is better than many.
Originally Posted by Astennu
Yeah dude, CCB1E 0550VPMW is a sick 165. The culprit to th ebad voltage scaling is more likely to be your mobo/PSU.
'Ve anyone got results from clocking an Opty 165 with this stepping:
CCBWE 0604TPMW
Anyone knows if this is a decent stepping?
Even 0550 VPMW's must have a few "duds" though, wouldn't you think?Quote:
Not really, most that dont clock high have been issues related to something else, mobo limitation, heat, psu, ram etc etc.Quote:
Originally Posted by Aversio
Oh man, now I just want one all the more. Thanks alot! :slapass: :stick:
Just got my 170 0551 UPMW.
Tried same settings as my 146@2900 and it booted into Windows but Prime crashed.
Tried same setting but@2800 and it Primes both cores 100% stable. 2800 so far... going to dual prime all night and see what happens.:D
Boy are those duallies hot.... needed to actively cool down the PWMIC..
I know, now you know where I am :slobber:
Yeah - I tossed an old case fan blowing on my pwmic last night... it was still going to 60c today in the afternoon heat.. gah!Quote:
Originally Posted by Badge56
my opty `65 CCBWE 0551VPMW is stable at 2.7 @ 1.525 volts, i didnt try lower vcore yet tho.
Exactly what mine did, seems to be the 165 average.Quote:
Originally Posted by Red.Sky
looks like my 0550UPMW is topping out at 2750 with 1.525v... 2.8 is doable with 1.6v... but it gets really warm.. even with watercooling.. during the heat of the day it was hitting 47c load... I guess that's not too bad, but I am used to 43c TOPS in the afternoon...
I might try 280 x 10 with a divider and see if that changes anything.. who knows... a little dissappointed... but oh well.
EDIT: I will likely sell this chip off, for a good deal also, along with my 3700 which does 3ghz and I will be on the hunt for a 3ghz dually . . . but after I get back from my travels, beginning of April.. maybe I'll get one for my B-day... w00t.
It'll be a tough hunt, good luck... along with me
I'd be happier if I had only bought a 165 which topped out where mine did. lol. I feel a little silly going for the 175 now.. but the 11x multi is nice... I can run my memory @ 1:1 now.. :) There will be chips out there for sale, I am not worried about not finding one at all, just when...
EDIT: in other news.. my new psu added 40mhz to my 7800GTX memory overclock.. I can hit 1390 now stable w00t.
i'd buy someones Opteron 170 CCB1E 0550 VPMW
wouldnt we all?Quote:
Originally Posted by noktekniq
my 0550 upmw isnt great either itll do 2880 low volts but prime is killing me.. core 1 fails after a few secs
Here is what my Opteron 170 is doing today.
[img=http://img47.imageshack.us/img47/982/my1stsp2004shot1rn.th.jpg]
I hope to improve on it, but will let things run to 24 hrs with dual SP2004 before I post again.
I got a Asus A8R32-MVP And A Coolermaster 550 Watt psu. Should be enough ?Quote:
Took my old venice for a spin but its much better already. Booted 290 mhz x 4 Htt. The Opteron 165 only did 250 max. Its also locking op @ a v-dimm of 2.85. I'll test the venice with my ballistix soon. It did 280 Mhz with those modules on a DFi Ultra D NF4. And the opteron could to 250 max. Its realy a weak one on the HTT and the MC side.
Is your LDT multi at 3x? Remember that LDT multi * FSB should not be more than 1000. Less is ok :)Quote:
PS: your avatar resembles mine a bit ;)
I just won ben805's old 170 on ebay.
0550UPMW, 2.9ghz @ 1.4v... heh $475 shipped. Not too bad.
