I love the low Vcore :toast: :clap:Quote:
146 CABYE 0540 FPMW (I hope I remember this well), on air.
Martin, you may have mentioned this before but what batch is you FPAW, plus BIOS running in the DR?Quote:
Originally Posted by Martin Cracauer
Thanks for the reply there Martin. CheersQuote:
50492 and 623-3.Quote:
Originally Posted by ncsa
Any Results of an CABYE 0542FPMW kown in the whole world?
Hehe let me know if you find any, I just recieved an 146 CABYE 0543FPMW :) :woot:
A friend has an CABYE 0542FPMW bought yesterday he asks for known Results.
yes i got one yesterday, didnt test mine properly as it struggles getting 3ghz stable, think there more 2.8-2.9ghz :(Quote:
Originally Posted by Rufus7
with CABGE 0536 am only up to FX55 speed. The only thing making a difference with speed is vCORE, period..ended up putting mem timings back to SPD raised HT back up to 5, ect.Quote:
Originally Posted by BadlyDrawnBoy
at 265 cpu setting cannot get sPI32M stable...270 and above is windows corrupt.
System as stands is BIOSTAR Tforce6100-939, 146, pair of 512MB SuperTalent CS2, WD2500KS, XFX 6800GS, Aspire X-Qpack...budget oc all the way.
Went with Thermaltake Big Water SE instead of Zalman...it did 36-38c with prime 95 a few hours.
So should I keep it as is? This forum reports CABGE 0536 is 2700/2800ish and mainboard is reported as max 272 cpu setting stable from review site. I think to go on is to RAISE Voltage even more...1.65v bios setting shows 1.54 in CPU-z after boot - next jump is 1.75, 1.85v ect. - Have room on temps but is big voltage jumps.
Any ideas??
http://members.cox.net/x64pc/x64dEFIANTFX55.JPG
Yesterday I removed my 148's IHS and reduced temps in about 10C! I was refusing to do that but reading your post I said, enough to that stupid heat. Now at 1.5V my temps are around 55C full load with an XP-120 and low RPMs :DQuote:
Originally Posted by D4nnyOcean
Thx before and tatts. And my 1700536MPMW struggled tonight with one Core at 2600Mhz and 1,36Vc after 3h42min by Prime 24.24 Custom. The Second core did it the whole night through. Thats not good news for me.
rufus, i tried again with my 0542fpmw today & does 2.9ghz occt stable with 1.55V but doesnt like 3ghz, even with 1.65V which is abit high imo, never tested anything between 2.9 & 3ghz though so dont know the max.
but im not to bothered as my cab2e 146 is looking very good :D
Today I recieved from newegg a 180 marked CCBWE 0543UPMW
In case anyone hasn't already seen a topless dual Opty. :D
Thanks. Looks like it came off so clean. The black stuff still looks pristine. What's your techinique?Quote:
Originally Posted by xgman
Originally Posted by gundamit
tis one came off easier than any one I have ever done. i juse use a ultra thin double sided rasor blade and start at a corner and slice evenly all the way around and then once more all the way around to be sure it's free. then use the tip of an exacto blade to gently pry one corner up. took about 2 minutes. the key is using a new sharp blade on each side if necessary.
you are pro, 2 min, my opteron is 1st cpu what i taked topless :P i took like 20 min , used razor blade, and f***d up 3 pins :P but i was lucky :nono: :D 10*c dropped in tempsQuote:
Can anyone point out which memory works best with DFI LP SLI-D/DR and does 250HTT+ @ 2.2.2.5?
i'm doing 270 2-2-2-5 with my redlines :)Quote:
Originally Posted by NYCTeeN82
2x Geil One BH-5 in SLI-DR:Quote:
http://www.cons.org/cracauer/oc-scre...perpi32m_1.png
http://www.cons.org/cracauer/oc-scre...erpi32m_1b.png
Bleh! Just got another 541RPMW... not even ganna open it, going to sell it or somfin.
how much did the last ?Quote:
Originally Posted by eBoy0
3500Mhz 3Dmark on me 146 opteron. Have to use ricky tweak otherwise coldbug wil max it out at about 335 HTT (stock mach II)
http://img.photobucket.com/albums/v6...39267small.jpg
http://service.futuremark.com/compare?2k1=8801379
Yea I've been looking at the Mushkin Redline XP4000. I can't seem to find many places online that carry them. Can you show me some places that have them and are fairly a good price?
