Here is my stacker!!
http://img149.imageshack.us/img149/8505/833a.jpg
http://img28.imageshack.us/img28/83/833i.jpg
http://img704.imageshack.us/img704/87/833h.jpg
http://img140.imageshack.us/img140/9057/833f.jpg
Alexo nice setup :up:
http://img230.imageshack.us/img230/8882/finalpic5.jpg
http://img140.imageshack.us/img140/3985/finalpic1.jpg
http://img63.imageshack.us/img63/3453/finalpic2.jpg
http://img651.imageshack.us/img651/413/caseout.jpg
EK Waterblocks EK-Supreme
EK Waterblocks EK-FB
Swiftech MCP355 EK
Waterblocks EK-DDC EK-DDC-X
iandh SteathRes 225 iandh225
ThermoChill PA120.4 PA120-4
CoolerMaster 2000RPM
PrimoChill PrimoFlex PRO LRT
Arctic Cooling MX-3
IandH Dead-Water Copper Sulfate Biocidal PC Coolant Additive
Steel Spring Hose Clamp for 3/4" OD Tubing - Black
Arctic Cooling F12 120mm
Logisys 15" Cold Cathode Replacement Tube - White
Please remove the picture links from your post.
Four Simple Rules:
1) No larger than 1280 x 1024 pixel (but 1024 x 768 pixel is preferred),
2) The limit on the number of pictures is 4 per case (if you want to post more than 4 pictures, use thumbnails or post links without using the IMG tags),
3) Do not quote images,
4) Finished cases only, no worklogs.
Optionally, it would be nice if you could list your water cooling components.
Not really a hole case, rather a small unit for my testrig. Build within an hour.
Eheim Station 600, Alphacool Yellowstone "Classi, ROG Edition", Clearflex 13/10mm, old Nexos triple radiator.
http://www.abload.de/thumb/img_0096359w.jpg
http://www.abload.de/thumb/img_0097n6m5.jpg
O nice, hmm Litle Devil graphics card backplate? I been missing something? :D
Still cleaning up my own build, water cooling tubes going around everywhere need get them hidden before posting pics.
DOOOD! nice build! :) that's awsome clean! i aprove!
and some new pictures from me :)
more in Gallery
http://www.abload.de/img/dsc01064jc3g.jpg
http://www.abload.de/img/dsc01051yfcx.jpg
http://www.abload.de/img/dsc01033jel3.jpg
http://www.abload.de/img/dsc010484ey7.jpg
That is absolutely awesome Screamer!!! But how on earth do you get your tubes to not kink??
Screamer, VERY nice build and nice pics! I too want to know how you got those tight radius bends without kinking? What tubing did you use?
Also looks like in your parts pics, that u used some Bitspower swivels, did you find that any of them leaked on you? I'm having some trouble with a batch of their 90's leaking at the swivel and after wetting down my board twice now am VERY leary of using them.
Screamer I'm speechless, what a killer build! How many radiators can the case really fit underneath with your PSU? Sure if you needed say an extra 240 it would fit right? Spent some time in your gallary, very impressive!
-Systemlord
Nice to see another modded CM around, here goes mine.
http://img233.imageshack.us/img233/5792/verniz1.jpg
http://img708.imageshack.us/img708/9484/verniz4.jpg
@Barr3l Rid3r
How hot does your chipset run with these clocks and voltages?
My guess is you should be able to melt lead on it, cause mine is pretty hot on a 790X with just a slow side fan blowing at it and far humbler clocks/voltages
Thanks Guys :)
Mudgey, Johnmark
I use Tygon 15,9/9,5mm. It's very flexible and can be really tight cambered. It's the best tube which I had.
Regarding Bitspower swivels I had only one bad unit but it was the old version (cube)
Systemlord
I have two radiators: 480 in "basement" and 240 in 5,25" bays. At the bottom except 480 will fit another 240 radiator, but will be no place for HDD.
http://d.imagehost.org/t/0656/DSC07902.jpg http://d.imagehost.org/t/0750/DSC07903.jpg http://d.imagehost.org/t/0380/DSC07906.jpg http://b.imagehost.org/t/0277/DSC07907.jpg http://b.imagehost.org/t/0382/DSC07909.jpg
Time to show mine
http://dl.dropbox.com/u/9421425/IMG_0058-1.jpg
Almost finished, just a few more adjustments
http://i759.photobucket.com/albums/x...6/DSC05211.jpg
http://i759.photobucket.com/albums/x...6/DSC05220.jpg
http://i759.photobucket.com/albums/x...5/DSC05135.jpg
2nd pic... is that a tiny bit of liquid in the block? May be a dumb question/observation, but why isn't it completely full/empty?
What's up XS. Just added the second card to the loop with the same block as the above one. EK plexi+nickel
http://www3.picturepush.com/photo/a/...-water-016.jpg
http://www4.picturepush.com/photo/a/...-water-017.jpg
http://www2.picturepush.com/photo/a/...-water-019.jpg
