IP35 PRO on-board optical SPDIF input to PCI soundcard
Does anyone know if it is at all possible to use the motherboard on-board optical SPDIF input to pass the signal over to a PCI X-Fi sound card?
I want to route an optical out sound signal via the on board Soundcard for 5.1 surround sound
Any ideas or advice would be appreciated.
where in BIOS should my IDE cd/dvd be listed
I'm building a new Intel core 2 duo IP35 Pro system. I have booted from a Flash Drive and flashed to the latest BIOS.
It worked great.
I installed an unformated SATA HDD
in SATA port 1. I installed a Samsung SH-SH182D CD/DVD burner
in the IDE Port. When I start the system, it gets to the "detecting IDE drives" then it lists my HDD drive model in SATA 1 and the other 5 SATA ports blank, which is correct. It then goes to the next page
and lists (in a green color) "0DD0 TSST CD/DVD SH182". I'm not sure why the green color and what the 00D0 means. When I go into
BIOS I can't find any reference to any IDE drives at all. I'm trying
to change the boot order to my Samsung CD/DVD so I can install windows. In the boot order part of BIOS the only CD ROM that is possible to choose is USB CD ROM. What do I need to do to get this done? Thanks for any help
