Should get that chip on phase or DICE/LN2 asap :)
OK here's some test, heat outside is killer over 33C im on AC at 23,9 Ambient Room not pointing to the PC just let the ambient cools to 24C as a reference
X3380@ 4009(422x9,5) at vcore load 1,184 / idle 1,2
http://img96.imageshack.us/img96/511...951125cust.jpg
i got temp diferences as u can see, Realtemp and Coretemp shows more, and Everest HWinfo, Hwmonitor show less, so i dont know who to believe...either way the chip is cooler than my vid 1,1875
Cheers :up:
Sergio
Very nice temps there. Scary start up vcore in easy tune though! 1.50v! That's no way to treat a lady ;)
lmao that was for trying 4905 wich booted lol, easy tune saves that i dont know where
also been testing this
http://img137.imageshack.us/img137/4...pl9bootdes.jpg
Ah ok. Looks like you will be having some fun with it anyway, congrats.
great fun :up:
i managed to drop vcore i love this chip :o) see how programs reports temps in dif way
X3380@ 4009(422x9,5) at vcore load/idle 1,184
http://img215.imageshack.us/img215/5...951125cust.jpg
X3380@ 4057(427x9,5) at vcore load/idle 1,20
http://img64.imageshack.us/img64/360...951138cust.jpg
I'm glad to see you're enjoying the new toy. Looks like the new chip does 4ghz without breaking a sweat, very nice Sergio.
i have exact the same voltages stable with my Q9550 VID 1.1375. but looks promising
Hey Sergio those volts looking good so far in you et6 and cpu - id cant wait to see what that xeon going to do :up:
Thanks Tony :up:
lol ET6 keeps remembering my first boot at 4817 lol with all volts i used...dont know how to make it read same as im using
Newer version of ET6 are crap...i installed a B09 one but i remember i've used a very good one B08 ish...that i dont have anymore
Cheers :up:
Sergio
That's very nice for a first boot mate - didn't know about this thread...
1.40 for vtt is absolutely lovely for 4.8....means the CHIP will last...:D:D
where did you get your's from if I may ask????:shrug::shrug::shrug:
Thanks:up:
been testing and tweaking to learn this new beast amazing chip temps under 50C at 23,8C ambient with tons of heat outside, very hot summer here...
this is 2hs blend and still going to 3hs
http://img132.imageshack.us/img132/4182/capturaix.png
Cheers :up:
Sergio
4GHz come on man wind her up a bit :) You're turning into a grandpa like me lol.
Well after topping out at 4300 stable and figuring out my ram limitations that where actually quite good if i need to push to 4500 .. Im back at 4.0 lowering my vtt and and reference as low as possible to see how low I cant get my vcore , once I hit that I'm go back up 100mhz at a time adjusting vtt and vcore as needed to stable at higher speeds ... here's last night results not the best but not the worst either :)
Intel Q9650 @ 4050 4 4 4 10 1.1 Stable Setup A
http://i84.photobucket.com/albums/k7...ableSetupA.jpg
if you think thats amazing read this post the last 4 replies or someting
http://www.xtremesystems.org/forums/...203236&page=35
Coretemp sometimes reads the low vid rather than the high vid. You need to have a screen of real temp showing min and max vids ;)
