Oh I plan on priming for overnight once I get closer to my desired settings. Usually a quick 5-10 minutes can tell me it's too shaky when I'm changing things a lot.
Thanks Seanie, I'll keep that in mind to let it run completely. I had mostly been just experimenting, not tightening yet. I was mostly wondering if that logo screen freeze, then boot fine next try was a symptom of the failed overclock feature or the shutdowm feature or something.
did some fast clocking with my q6600.. this was done with watercooling.. core voltage was 1.5v sorry but i cant remember the other volts that i used.. oh and dont pay any attention to that superPi score i was testing the stability there :D
http://i163.photobucket.com/albums/t...os/3915mhz.jpg
joining you guys soon... once i get my board and a new processor. :D
Benn lurking here since I bought this board back in July and now just finding time to o.c. and soon to add a new w/c system
I have run memtest with my ram at 1003mhz - 2.15v - 266/667 strap with 2 full runs without errors but when I am in windows and run prime 95 blend I get a fatal error after about 8 seconds? Since this is my first time o.c'ing what is my next move?
some of my settings:
12/24 bios
dram settings all on auto
cpu vid: auto
dram: 2.15
sb: 1.07
sb/cpu pll: 1.55
nb: 1.45
cpu vtt: 1.35
gtl: disabled
fsb: 400 x 7 = 2.8
266/667
ddr2 1003mhz
stock cooling for now...temps all seem within a decent range.
I am new to this stuff so any specific feedback to setting would be greatly appreciated!
I would say if you are failing Prime straight away with the CPU on stocks and the memory is stable you say after mem testing, My first Question is to what % did you memtest too, secondly, if the board is causing the failiures, then try a bit more NB and/or VTT voltage,.
Finally download memset3 beta 4 I think is the latest release, write down the timings and then goto your bios and hard set them, with them on auto the board could effectivley be changing them each time you start up your machine.
http://www.xtremesystems.org/forums/....php?p=2694020 (MemSet)
Just a bit of fun before I go back to the X38 board.
http://www.edgeofstability.com/image...Pi_445x9_s.jpg
http://www.edgeofstability.com/image..._445x9_a_s.jpg
Well I got 8x450 / 3.6ghz / 4 4 4 12 900mhz 3 hours blend no problem at 1.4vcore.
http://img255.imageshack.us/img255/9...3hrsfm2.th.jpg
That's basically the same I used to run my P5K-DLX 24/7 with the same mem/cpu combo, only 9x400 was more stable on the P5K and the 8x450 seems better on the DFI. I need to learn this bios. I think I'll let it prime overnight at this setting just to get a solid 8 hours.
Fooled around with 4ghz for a little fun, picking up e8400 asap, maybe tomorrow.
4ghz -
http://img258.imageshack.us/img258/4...s4piqv8.th.jpg
cpuz dump -
http://img258.imageshack.us/img258/9025/cpuzyr4.th.jpg
Does anybody have an E8400 on this board? I cannot get over 440FSB no matter what I try and if that is the wall on this chip I will flip out. :mad:
Did you try it in another board/bios?
2 Bios's and I am not gonna tear down my HTPC to test this chip on air.
I am wondering if it is the BIOS. I am on LP35D109, so I dont know if it is very good and I also wonder if 45nm support is alittle off. I find it odd that I cannot get close to 4Ghz and others are getting it at 1.23v and air cooling.
If I dont get very far soon I will toss it on RFD or Ebay.
I was just a little thrown off by your sig so I asked about the two boards.
Good luck, hope it works out for you!
Ya sorry, it is alittle confusing.
I wanted to test the E8400 under water before moving it over to the HTPC and get some decent aircooling and put the quad back in my rig.
I had some high hopes for my E8400 as it has a VID of 1.1v, but when I put in in the system I noticed that the temps from core to core were off by about 10c. Not a great start, and now it is either walled at 440 FSB or the DFI BIOS is bugged. I sure hope it is the latter....
I even got a decent IHS this time and the thermal diode is hooped on the chip and I cant get a better OC than a bloody E6750. I guess thems the brakes.
Will give it a couple more tries then I fleabay it.
Here's a crazy question, how do you switch between 1T and 2T timming, I thought it may of been something to do with T2 Despatch, but I have that option currently Disabled and still running 2T. I see no Command Rate Option in the Bios :shrug:
Hey Seanie I was looking for that too. Best information I could find was in this post in section Clock Setting Fine Delay, but I haven't tried to adjust it yet -
http://www.xtremesystems.org/forums/...&postcount=689
I wasn't talking hear-say, but based on my experience. I've used this method on several DFI board i've owned and it worked fine, never had any issue. I agree that perhaps using USB is better, but i don't see why not use WinFlash to do it if it's done properly.Though i haven't had a floppy for ages...
I had to gank a floppy from the office so that I could have one on hand for this board. haha it's tan plastic and brings back memories.
no problem with 550 FSB on 45nm for me guys. Using latest official bios. It must be the chip. Make sure you set GTL's to 70 - 80. 1.57 vNB minimum and give it a bit more VTT voltage aswell.
I have played with this & was unable to get my board to post much higher that 850mhz or so on 1T.
Auto sets 2T & when you set 3T CPU-Z reports 1T!! yet Memset says 2T!!
3T set in BIOS regardless of what CPU-Z / Memset says is slightly slower in Super Pi & it allows your RAM to clock a little further so I am sure it really is 3T.
Here is a screen shot showing 1T when I set 3T!!
http://i106.photobucket.com/albums/m...51TEverest.jpg
It's my first post here - I managed (don't know how :shrug: ) to get through all pages of this topic - great work - I really appreciate your input :up:
It's only few hours for me to play with Q6700 but I managed to get it StressPrime stable @3,6GHz (450x8) and Vcore @1,5V using 4x1GB of RAM... Voltage optimization in progress... 4cores@3,6GHz is enough for me, but voltages should be lower to make me happy :cool:
http://img220.imageshack.us/img220/2...loadql3.th.jpg 3DMark06 ORB
More than 3,6GHz is just pure play, so I tried 4GHz setting
http://img235.imageshack.us/img235/7...32mbym1.th.jpg 4GHz validation
My Q6700 @4GHz is SuperPi32MB stable (:D ) but I can not dream of StressPrime stable - needs more juice and better PWM cooling as I noticed StressPrime failure at about 65stC. PWM waterblock upcomming...
Funny thing is that there is (in my opinion) 10 deg C difference between cores during load... Maybe it's due to my quick CPU instalation (without separateing WC) anr/or Arctic Ceramique bad application. Upcomming WC modification will show me what is goin' on :shrug:
what's your proc gonna be Matt?
wish the Penryns would be available where were at...:shakes:
well here's my 24/7 clocks... any comments would be appreciated... :)
http://i116.photobucket.com/albums/o...Hz-TeamX-1.jpg
DFI™ LanParty UT P35-T2R (12/24 Bios)
Intel™ Core2Duo E6850 with Thermalright™ Ultra-120 Extreme
Team Xtreem™ DDR2-9600 2x1GB with Thermalright™ HR-07
XFX™ NVidia™ 8800GTX with Thermalright™ HR-03 Plus & HR-11
Creative™ Sound Blaster X-Fi™ XtremeGamer Fatal1ty Pro
Western Digital™ Raptor 74GB & Seagate™ Barracuda 500GB SATA
Silverstone™ DA750
Code:>CPU Feature:
Thermal Management Control.......... - Disabled
PPM(EIST) Mode...................... - Disabled
Limit CPUID MaxVal.................. - Disabled
CIE Function........................ - Disabled
Execute Disable Bit................. - Enabled
Virtualization Technology........... - Enabled
Core Multi-Processing............... - Enabled
>DRAM Timing:
Enhance Data transmitting........... - Fast
Enhance Addressing.................. - Fast
T2 Dispatch......................... - Disabled
>Clock Setting Fine Delay Press Enter:
Ch1 Clock Crossing Setting......... - Auto
DIMM1 Clock Fine Delay............. - Current[245ps]
DIMM2 Clock Fine Delay............. - Current[645ps]
Ch1 ControlFine Delay.............. - Current[957ps]
Ch1 ControlFine Delay.............. - Current[712ps]
Ch2 Clock Crossing Setting......... - Auto
DIMM3 Clock Fine Delay............. - Current[245ps]
DIMM4 Clock Fine Delay............. - Current[712ps]
Ch2 ControlFine Delay.............. - Current[957ps]
Ch2 ControlFine Delay.............. - Current[645ps]
Ch1 Ch2 Common Clock Setting....... - Auto
Ch1 RDCAS GNT-Chip Delay........... - Auto
Ch1 WRCAS GNT-Chip Delay........... - Auto
Ch1 Command To CS Delay............ - Auto
Ch2 RDCAS GNT-Chip Delay........... - Auto
Ch2 WRCAS GNT-Chip Delay........... - Auto
Ch2 Command To CS Delay............ - Auto
CAS Latency Time (tCL).............. - 5
RAS# to CAS# Delay (tRCD)........... - 5
RAS# Precharge (tRP)................ - 4
Precharge Delay (tRAS).............. - 8
All Precharge to Act................ - 4
REF to ACT Delay (tRFC)............. - 26
Performance Level................... - 6
>Read delay phase adjust Press Enter:
Channel 1 Phase 0 Pull-In.......... - Enabled
Channel 1 Phase 1 Pull-In.......... - Enabled
Channel 1 Phase 2 Pull-In.......... - Enabled
Channel 1 Phase 3 Pull-In.......... - Enabled
Channel 1 Phase 4 Pull-In.......... - Enabled
Channel 2 Phase 0 Pull-In.......... - Enabled
Channel 2 Phase 1 Pull-In.......... - Auto
Channel 2 Phase 2 Pull-In.......... - Enabled
Channel 2 Phase 3 Pull-In.......... - Enabled
Channel 2 Phase 4 Pull-In.......... - Enabled
MCH ODT Latency..................... - 1
Write to PRE Delay (tWR)............ - 10
Rank Write to Read (tWTR)........... - 10
ACT to ACT Delay (tRRD)............. - 3
Read to Write Delay (tRDWR)......... - 8
Ranks Write to Write (tWRWR)........ - Auto
Ranks Read to Read (tRDRD).......... - Auto
Ranks Write to Read (tWRRD)......... - Auto
Read CAS# Precharge (tRTP).......... - 3
ALL PRE to Refresh.................. - 4
>Voltage Settings:
CPU VID Control..................... - 1.37500v
CPU VID Special Add................. - Auto
DRAM Voltage Control................ - 2.19v
SB 1.05V Voltage.................... - 1.070v
SB Core/CPU PLL Voltage............. - 1.55v
NB Core Voltage..................... - 1.41v
CPU VTT Voltage..................... - 1.30v
Vcore Droop Control................. - Disabled
Clockgen Voltage Control............ - 3.45v
GTL+ Buffers Strength............... - Strong
Host Slew Rate...................... - Weak
GTL REF Voltage Control............. - Disabled
CPU GTL1/3 REF Volt................. - 95
CPU GTL 0/2 REF Volt................ - 93
North Bridge GTL REF Volt........... - 95
Genie BIOS Settings:
Exist Setup Shutdown................ - Mode 2
Shutdown after AC loss.............. - Disabled
O.C. Retry fail counter............. - 0
CLOCK VC0 divider................... - Auto
CPU Clock Ratio Unlock.............. - Enabled
CPU Clock Ratio..................... - 9
Target CPU Clock.................... - 3780MHz
CPU Clock........................... - 420
Boot Up Clock....................... - Auto
DRAM Speed.......................... - 266/800
Target DRAM Speed................... - 1260MHz
PCIE Clock.......................... - 110mhz
PCIE Slot Config.................... - 1x 1x
CPU Spread Spectrum................. - Disabled
PCIE Spread Spectrum................ - Disabled
SATA Spread Spectrum................ - Disabled
@ray
I'll hold off till the E8400 arrives. Thanks for the board. :D Hope to receive it tomorrow. hehehe
What bios was in the board that you sent?
