I have tried the cmos clear, still no luck. I can get x4 using the secondary slot. However, I want x16
Boy, I am getting tired of the long beep with three short beeps to follow when
I bootup.
what is the difference between cmos clear and a new bios update?
Cmos clear just resets the bios settings to default. A bios update changes the bios version (ie. the code which runs the motherboard).Quote:
Originally Posted by samork
ok, I think I will clear cmos again..........thanks
got it to post finally 24 method worked.
what is the 24th method???
i believe its when you unplug power cable, set cmos to clear and remove the battery for 24 hours.Quote:
samork I think you should RMA the board if you can never get 16x PCI. Ive never had it running any other speed than 16x even with the stock BIOS it shipped with.
I updated my p5b-d with 1004 bios, it looks great but I wanted to change it older one for memory test..
Well, I found that 1004 bios can't be downgrade to older bios..
I tried AFUDOS, EZflash, ASUS Update, but nothing works..
Anybody tried it? If someone succeded it, plz let me know how to.. :(
I guess you should have read this firstQuote:
Originally Posted by flaker
Description P5B Deluxe Release BIOS 1004
**Please update AsusUpdate to V7.09.02 or later prior making this update.**
**This BIOS does not support roll back to older BIOS**
1 Enhance memory compatibility
2 Support CONROE E0 CPU(FSB 1333)
:nono:
You'll have to order another bios chip
thank good i didn't update my bios to 1004 yet
It was written as below before I downloaded..Quote:
**Do not use AsusUpdate to downgrade BIOS. For such need, please use EZFlash or AFUDOS instead**
1) Enhance memory compatibility
2) Support CONROE E0 CPU(FSB 1333)
Now it's changed.. lol..
That was before they posted it on the main bios page.:p:
I saw the red warning letters and decided to play it safe and read about it here first before I tried it:toast:
Return the board ASAP. Don't even think about anything else.Quote:
Asus can sometimes really catch from behind reaching for a soap, don't they? :slapass:Quote:
I choosed not to upgrade yet, to see what are experiances of other, but if we all did that, we would have no one to compare to. So I admire ppl willing to test put new stuff, esspecially coming from Asus :clap:
I am having problem, Soundforge 8 doesn't detect the audio device at all for recording. Have any of u experianced this issue?
I will try later on today, to do front header as new device to see if that resloves issue. I dont have any issue with microphone in other apps
EDIT : ISP gone crazy
EDIT: Double post ISP gone crazy
A.I Nos works with the CPU defaults . no other OC possible.Quote:
Originally Posted by pumbertot
Since I don't have a need to OC higher , I prefer this situation ATM.
I should OC the memory though..
I'm having some harddrive problems.
Specs:
Asus P5B Deluxe (Bios 0910)
Maxtor 200gb sata (6L200m0)
Vista Ultimate
I noticed that while playing audio and video files I was getting a lot of stuttering/freezing, so I ran a HDD benchmark
http://www.woutfunnekotter.nl/images/sisoft.jpg
I tried switching SATA ports, which didn't do anything. I've installed the latest intel chipset drivers too.
Any thoughts? This drive was working fine in my old system (on a DFI NF4 mobo)
It looks like you're SATA is configured for IDE in the BIOS - which is the default for that motherboard. Change it to AHCI. See page 4-14 of your motherboard manual :)Quote:
Originally Posted by Wout
Anything on this guys?Quote:
Originally Posted by Stx
thx
The strap changes at 401.
You did install the Vista Version of Asus drivers ? also, you could get Intel's latest (early januar 07) directly .Quote:
Changing it to AHCI causes a BSOD while booting. I assume I need to reinstall Windows for this to work?Quote:
Originally Posted by ThreeNF
Also, another question. I'm planning on adding two WD raptors next week for a RAID 0. Should I set the SATA controller to RAID then, instead of AHCI?
It is even possible to have a normal hdd, plus 2 hdd's in RAID on the Intel controller?
If you're going to use RAID, then I would use the SATA_RAID connector on the motherboard. That connector IS set to AHCI by default, whereas the standard SATA connectors are set to IDE.Quote:
As for the BSOD, I'm not sure what is going on there. Maybe since it is Vista, you need a different driver?
The SATA_RAID is the jmicron right?Quote:
So you mean, plugging my normal SATA HDD in the jmicron, and then plugging the upcoming RAID disks in the normal SATA ports?
I assume I need to install the Intel driver first, before I can set it to AHCI. Problem is, the setup won't run saying that my computer doesn't meet the minimum requirements. The Intel driver has vista support (http://downloadfinder.intel.com/scri...stems&lang=eng)
