lukija, hm....i have a request :)
My problem is that i always need to use memtest in bios to see the memory bandwidth when i change some DRAM setting in bios.
It would be very nice if we had one tool (like A64info) where we can change all the settings, AND the clocks, FID, VID etc.. (like nf4clock gen)...and ithad a function where it does some testing to see the theoretical bandwidth of memory as in memtest.
Then you could switch some value, like TRCD, TWTR etc...and see the theoretical result in A64info ! Like "2997 MB/s memory bandwith" and i dontneed to check what memtest says.
You could also include some information about memory latency, maybe.
Just an idea :)
Edit: Other idea..well..iam bored...so i thought i give you some input..lol
There are certain rules of thumb for certain DRAM values, one here
http://www.broadbandreports.com/faq/9222
(eg.
tras should be cas+ trcd + 2)
trcd= trp
trc=tras+trp
trfc=trc+2
etc...those are general guidlines...and i often use this to calculate my stuff. So...there could be a help-fuction in a64info where you use this formulas..and when you enter a value it could auto-adjust/suggest values for the others. Just an idea.
