Yes they have :slapass:Quote:
card is officially dead ;(
replaced both mosfet's & tried to boot & the same mosfet went up in flames. When I mean flames, it burst into flames & melted my solder joints & fell onto my motherboard :eek: Was burning for about 5seconds with a nice yellow flame..
Nothing else was damaged luckily.
C-BuZz
Sorry to hear though you maybe could have made a fortune selling the video of the fireworks :eek: :D
heh, can always solder another in its place :)Quote:
Originally Posted by alpha0ne
C-BuZz
@graham - did you take that picture? maybe you could get the full codes of the largish elongated chip about an inch below the 0605 date stamp. that'll be the vgpu controller i would think.
the two 8 legged ones at the below that chip will probably be for the vmem. full codes would help there too.
thanks
flytek it is my card I'll try and get some more with a bit more detail
exellent. also it would be very interesting to find out what coolbit's nvidia driver autodetects the core/mem frequency overclock at.
something else of great interest would be stock frequecy clocks and a 3dmark06 run.
lastly the codes of one of the ram chips would be very nice to know. for all we know gainward changed that on these golden samples
Sorry to hear.Quote:
Originally Posted by C-BuZz
To find the reason is not easy, but for a mosfet to explode into flames, probably means that it was not fully turned on while transferring lots of current and because of that is dissipating huge amounts of heat.
The device responsible for controling this mosfet is the voltage regulator, so my guess is that your voltage regulator is no longer working properly.
Replacing this device is beyond the scope of a hobbyist, but chances are high that your memory also received a voltage that was too high and is damaged because of this.
You could try to test the board with an external power source (with both mosfets removed) to find out if it is worth investing any further.
how would I power the card with an external source?Quote:
Originally Posted by t024484
Im just guessing, but I dont think that the current flowing through the mosfet is supposed to be so high? Would have to be at least 12v to do damage like that? The chip it totally unrecognisable & basically turned to powder.
C-BuZz
Sluggo, your information is both wrong and misleading.Quote:
Originally Posted by sluggo
Wrong because the 32n03 has a total gate charge that is only half the gate charge of the 4420 that it replaced, wrong because a turn-off delay does not generate heat, and wrong again because the Infineon turn-off time is in fact shorter than the IR part.
Misleading because charging and discharging a capacitor does not generate any heat in that capacitor (or Mosfet), apart from the (mostly neglectable) loss factor.
And as a last remark, the switching frequency for Vmem is 660Khz and not 250Khz, and has never been overclocked by anyone as far as I now of.
you mean the main vpgu voltage regulator t024484? maybe the vgpu mods are staining the vreg in the wrong way and leading to the vmem mosfets burning out?
Nasty. Did you remove all mods including the pencil rub first?Quote:
You could always *try* to RA it and say "it just blew up!" lol
The mosfet that is burnt out is connected to the 12Volt, and your memory needs just 2 Volt. Suppose that 10Amp is flowing with a Drain to Source resistance of 1 Ohm, this will generate 100Watt, more than enough to blow your Mosfet to pieces.Quote:
What you need is an external power source capable of supplying 2Volt and preferably something between 15 and 20 Amp, and of course with a good short circuit protection. If you cannot borrow this somewhere, there are companies specialised in renting such electronic equipment.
No I am talking about the 6549 Voltage regulator for Vmem.Quote:
This one works completely independant and is not influenced in any way by the 6568 voltage regulator for Vgpu.
it's a real pleasure to have you on the board t024484 ;)
He is a bit of a legend. Is that a crocodile embryo as your image? Or a Jurassic Park promo pic? :slap:Quote:
Nail on the head. It is a Croco embryo.Quote:
Originally Posted by xit
Thought so....damn they're tasty. :stick:Quote:
Anywho, back to the 7900's !!
I wasn't comparing the 32n03 to the 4420, I was comparing it to the IRF7821. The guy with the burnt chip was considering replacements for his fried 4420 and I was advising him on the pros and cons of the those two alternatives.Quote:
I didn't say or imply that turn-off delay created heat. I mentioned it only as an illustrative consequence of the higher gate charge.
Discharging a capacitor most certainly does generate heat. A current has to remove the charge, and that current has to pass through a conductor with some finite resistance.
My mistake on the frequency, the Vgpu switches operate around 250kHz and that number stuck.
graham_h,Quote:
Originally Posted by graham_h
You certainly bought the 7900T/512 because you were looking for an improved performance.
Do you already have comparable results between the 7900GT and this new board, both with the same clock speeds.
That would be great to see.
Where are you guys getting your GW GTs from?
Hello guys,
I've roughly read through this lenthy discussions. Nice mod really!
I had a card vmod 1.4v, no vmem mods.
640/900... not a big overclocker but I am satisfied with it. :)
My question is about those MOSFETs.
In my case, they got extremely hot. Though the computer is quite stable even without heatsinks, I dare not put them.
After putting them on, the heatsinks still measure ~70 degrees celcius or up (well, with my fingertips... maybe not very accurate...)
so I managed to put a fan to blow some air onto the chip and the heatsink, and then... my motherboard temperature goes up about 5 degrees!!
How hot actually are those chips?
I am starting to think it is after all not a very stable mod...
I am curious about their functionality. Why are the two switching to each other? What do they actually do?
One chip is the voltage regulator for the memory voltage and the other one is a Mosfet connected to this regulator.Quote:
Originally Posted by timchen
Together with a third Mosfet they form a "switching regulator" to make 2Volt out of 12Volt with a relatively high conversion efficienty.
So the Vgpu modding you have done has no impact on the heat development of these components, but of course the memory overclocking to 900 has. Going from 650 to 900 let the current increase accordingly.
A heatsink is very good, and 60-70 degrees seems O.K.
The ventilator you are using is probably directing its flow to the measuring diode on your motherboard, thats why.
Where/how would I connect such a power supply to my board with no mosfets?Quote:
I concur :toast:Quote:
C-BuZz
