What are that case dimensions?Quote:
Hmm, why switch to R507? didn't R402/R410 worked?Quote:
I bet you could do it with a coaxial heat exchanger above the condenser, plate HX vertical orientation would make it hard.
i like the condenser your using there LD, so these rotaries are they 1hp or tad bigger, what mains frequency they run at?
Ya got pm
Search the Vapochill fora for modifications, they say it's compatible with R404a but startup problems CAN occur.
I modded a VapoXE once and it works flawless with R507 ;)
OMG!!!! :shocked:
Nice job from GLS transpoint.:mad:
Too bad for Bowtie :(
Duronbird, let's hope yours and mine is ok.
That sucks guys. I seen Luke XE say how bad GLS are. Hope LD can remake and clame on the insurance
Guys i almost cannot belive what i see on those pics :eek: Guys please send me PM with info of all units, i'm already in contact with GLS.
Best Regards
what a shame.. masterpiece ruined by some stupids :@
Little things goit to do with my SS too...:confused:
Here's some pictures.
boble76's Rotary SS
What do you think about..? :D Just a little repair.
Where they playig football with the box or something?Quote:
Originally Posted by Boble76
Impressive! Not words...
ps. I received my SS from LittleDevil in excellent condition.
Oscar
Guys, please contact me on PM!
regards
Damn some of those guys who work at GLS are real bastards. It looked like those units have been thrown around like a bloody tennis ball :mad: .
Were the packages marked with fragile etc? Maybe more people should start using pallets like cold_ice does. That way there is never really going to be any damage, unless it falls off the stacklift truck(s).
Holy :banana::banana::banana::banana:... how did they broke off the fan?
Brettbeck: I packed them really good, i ordered special boxex for those units...
Moc: Dunno...
regards
Did you filled the inside of the cases with something?
LD packs dude...just look at some of his posts of unit he has sent out and users that have them delivered. GLS seams a really :banana::banana::banana::banana:e company to use but sadly about the only one that will take the job on. Insurance aint it great
Yes, thats really good packed!
But I wanted to know if LD put sth. IN the Phase-Change Case?
Some new pics, thanks Dimas for condensors ;)
Load test on all units today :p:
http://ld-phasechange.com/images/Oliver's_SS/4.jpg
http://ld-phasechange.com/images/Oliver's_SS/6.jpg
http://ld-phasechange.com/images/Oliver's_SS/7.jpg
And some V2000kits:
http://ld-phasechange.com/images/GIL...V2000kit/6.jpg
http://ld-phasechange.com/images/GIL...V2000kit/7.jpg
http://ld-phasechange.com/images/GIL...V2000kit/9.jpg
http://ld-phasechange.com/images/tjelaw's_V2000b/11.jpg
http://ld-phasechange.com/images/tjelaw's_V2000b/10.jpg
http://ld-phasechange.com/images/tjelaw's_V2000b/9.jpg
Best regards
Hmm, seems like the bolts that keep the rotary compressor helt to it's base cracked or have been loosely tightened. Otherwise the outside of the package looks nice. If the problem was with the GLS shipping, the damage to the packaging would be visible, right?
LD, inspect those bolts & housing ASAP! It seems like loose compressor is making the pasta out of interior... :( From an engineering stance I can tell you that there is something very wrong in the design of this case. The weight distribution with rotary compressors isn't the same as they're higher thus making bigger momentum on the structure of the chassis, especially on the bolts. You really need to redefine something in this chassis.
Just my 2 cents.
Awesome job as allways LD. Do you paint the brazed joints so you don't have to clean them to make them shine :p:?
@tiborrr: Thank you for your advice, but problem isn't in case or bolts but i got too small washers... And we will solve that problem too so there is no problem....
@Brettbeck: Only for better looking, i always clean brazed joints...
Regards
Great job on the finished product. You always do a great job making it look completely finished without shortcuts of any of the builders. Keep up the good work LD.
