Originally Posted by Roger_D25
Deimos,
Thanks for the suggestion, it's probably the only thing I havn't done yet! It's now been almos 2 days and most of my problems have worked themselves out as weird as that sounds. Initially I was unable to run benchmarks, play games, or change clockspeeds either manually or by using the "Detect Optimal Frequencies" option. I could physically change the sliders to different speeds, and I could also hit the "Test Changes" button. The problems didn't start until after that when the "OK/Cancel" window would pop up after hitting the "Test Changes" button. If I clicked OK, my screen would immedietly fill up with artifacts, blinking on/off, and eventueally shut my system down.
Then late last night I tried for the hundredth time to manually change the clock speeds, well this time it worked fine, I clicked "Test Changes" and it did it's little test with no problems. After that I tried playing CODII for the hundredth time (every other time I played anygame it would just shut my system down within 3 minutes), again this time it worked fine! I played for about 2 hours with no major issues. The only problem was very minor artifacting when the background color was white, oddly enough after playing for about an hour this just went away and now I can play any game with no artifacts at all even if my card is overclocked.
The only remaing problem is if I hit the "Detect Optimal Frequencies" button. I just did and unlike every other time it actually went through the whole testing phase, then after it was done I went to hit "Apply" on the driver control panel and everything froze along with the same artifacting again? Because the problem is so random I can't make heads or tails of it?
All I have left to do is to pull the card out again and completly go through it with a visual inspection and to try the stock heatsink like you said. I didn't have any solvets to help remove conductive ink so I just used a tiny flat-head screwdriver and a magnifying glass to carefully scrape off resisdual ink but someone suggested using alcohol to remove any leftover stuff because it doesn't take much conductive ink to create a path between two things that shouldn't be connected! Thanks again guys for bearing with me through this!
