Is there a formula how to calculate the VCCA Voltage?
I though about using a 1000 Ohms poti and a 820 or more resistor, so you cant get the resistance lower than 820 Ohms or more. The used resistor should result in a voltage not higher than 1.9V or even 1.95V, so if i could calculate what is needed for maximum 1.9 i would be happy :)
