I tryed running higher clocks then 600. Hoping for no artifacts but it resulted in a lockup :'(
Ermm .. what did you use to flash bios ?Quote:
Originally Posted by FUGGER
Do you have a link ?
I want to grab the bios from my card and stick it in an editor to play with ideally ;)
Can you sent me your bios ? I got mine out with Ati Flash 3.04. But i need A bios from a card that can do 1.3v on the gpu without locking up after playin 3d for like 15 min. Mine locks up with all higer than 1.2.Quote:
Originally Posted by Bartflaster
wouldn't that be a temperature problem? what cooling on the card?Quote:
Originally Posted by Astennu
Nope Its on a Zalman VF700 CU. Its not under the 65c stressed. so that could not be it.Quote:
Originally Posted by biohead
Aure you on GoT to ? have you got an X1800 XL from sapphire ? if you have can you get past 1.25v ?
Found v 3.09 and got bios off .. were do you want it sent ?Quote:
Now what can I use to edit it lol ...
A Great !!!! :toast: :woot:Quote:
Astennu91@hotmail.com plz. I hope it will fix it. U have a Gecube ?
Tnx man !!
i ow u one :toast:
They are making an new version of rabit where u can edit voltages and clock speeds.
No .. mine is HIS ... but I think maybe bios are the same ... but its sent so good luck :)
I can only find rabit 1.6 that opens files, but it wont let me alter clock or core .. so now need an editor :rolleyes:
ooo just noticed you said a new version of rabit coming .. cool, I will keep an eye out on his site. :)
They are working on it. I did not recive it yet. could you send a second mail to frank.van.de.pol@kion.nl. Ty to rar the file maybe some virus scanners will block it somehow, I hope o get it soon so i can test it en hopefuly fix my 1.2 volt limmit.Quote:
Sorry I took so log getting back to you .. I hadn't remembered how fussy hotmail can be with attachments. ... and dont forget hotmail also tends to filter a lot of mail as junk when it isn't ;)
RAR file sent to other addy too :)
Oh dear :(
Mail undelivered:
"Hi. This is the qmail-send program at pandora.local.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<frank.van.de.pol@kion.nl>:
192.168.0.10 does not like recipient.
Remote host said: 550 <frank.van.de.pol@kion.nl>, Recipient unknown
Giving up."
I will forward it too the hotmail addy .. just look in your junk folder for one from bartflaster ...
why don't you just upload the bios here? :) cause i want it too. :)
btw has anyone found out how to edit those bioses yet? :)
I hope eventually we will be able to flash the bios with our desired clocks AND voltages so they will always be as set without having to run these applications in the background on each boot. Do any of them remain set after a reboot?
Originally Posted by cantankerous
they should stick with the new ATI Tool when its finalized and made public.
I have now new FX-57 (0528 MPMW) and also DFI Lanparty RDX200 CF-DR motherboard that runs fine @ 266 MHz (2-2-2-6) with Mushkin Redline XP 4000 memory. Lets see when the Radeon X1800 XT CrossFire edition arrives :)
My card dous suck :( can some one do a run @ 1.3v ? for like 15-30 min ?Quote:
Originally Posted by Troman
If u can run that voltage i will buy a new one. Owh and the tool undervolts if u set 1.275 u get 1.25v and if u set 1.3 u get 1.275v.
Someone plz test the voltage. I'm stuck @ 1.175 ( in real voltage 1.2 was set )
can you post the cf bios when you get it :) thx :)Quote:
Originally Posted by Sampsa
btw sampsa do you have a xt bios you could upload? :)
I thought it was mentioned that the XT bios does nothing for an XL card and infact an XL bios was best for an XL card.
Frugger said it. But i'm stuck on 1.75v max so i would give anything a try. i'm now testing 1.95- 2.0v ( real volts not the one set by the clock program ) And clocks so far are 650-800.Quote:
As an update .. just been playing GTL online for over an hour @ 600/1400 1.225v/1.9v no problems ... seems you have got a rare duff clocking card Astennu .... unusual, cos I normally have monopoly on those :p:Quote:
card never artifacted or locked up at all at those speeds? You try any other games? You try a higher clock or is that your max to remain lockup and artifact free?
That was my first test ... I know I can go to around 680/1530 possibly a little more .. but how stable it is I don't yet know ... I really want the ATitool so I can check for artifacts and set clock at windows start-up ... would make me feel more secure ;)
Same. I would like to enable 2D/3D profiling when the new ATI Tool is out.Quote:
Its such a hassel to keep on setting it up. I hope wizzard will enable profile support for voltages. :D
I don't like ATI Tool, I hope the new ATI Tray Tools in future Omega drivers will also support this.
Well, seems like they both struggling to get the OC'ing thing working.Quote:
