With 623-3 in yellow slots does not even boot to me.
Hey charlie,
You wouldn't happen to be "chopper_charlie" on BF2 would you? I saw someone spawn super fast with me and was wondering..........hmmmmmmmmmmm. :)
Well, with a bit of luck they'd probably do 290 or even more. I can run 1T with 4 sticks on my SLI-DR EXPERT. However, not at that high HTT, but i guess with BIOS optimizations it might be possible soon.. Either way 280 @ 2.5-3-3-7 2T should be faster than 260 @ 3-3-2-6 1T..Quote:
Originally Posted by JNav89GT
I don't think charlie ever successfully benched 3d is high clocks. That was before we knew of the 3d being the real tester.
max 3d for me around 273-275...Quote:
Originally Posted by bigjohns97
i did 3dmark 01 se testing on these modules.
lol... nope I'm XSCharlie or CharlieXS I can't remember!Quote:
Originally Posted by FlyBoyGeo
how high can u got 1T with ? I'm interested in these new 32x boards as well. I would like to see comparisons of 280 2t vs 260 1t at timings proposed, I'd figure the 1T would be faster.Quote:
Originally Posted by tjj
For insance, I had 4x512mb Redline at 2T at 2-2-2-6 at 250 compared to 3-3-3-8 at 250 and the Redline was just barely faster. Knowing roughly that 200 at 1T and 200mhz would be very close to 250 at 3-3-3-8 3d benchwise, I'd have a hard time believing that 20mhz would make up for the 2t loss given your loss of trp would hurt more as well, vs the almost neglidgeable help of cas 2.5 vs cas 3
Got my pair from mushkin tonight and so far they seem awesome! I havent tweaked them much, stuff is still on auto. What data/drive strength should I use? 8 & 3?
http://img222.imageshack.us/my.php?i...nred2gb8hq.jpg
http://img225.imageshack.us/my.php?i...red2gb21oj.jpg
Originally Posted by Nettwerk
do some 3D test and see what happened :D :D
Going to 2T is basically gonna give you the performance that you would get if you dropped 20mhz. I have tried this personally with Everest and SuperPi, and it comes out to be about exact. Scores were basically identical running 260 2T and 240 1T with the same timings. When in doubt, grab everest and SuperPi and run some tests yourself to find out which is gonna be better. i personally avoid 2T at all costs, id rather use a small divider...
Originally Posted by ben805
http://img218.imageshack.us/my.php?image=3d20019im.jpg
http://img218.imageshack.us/my.php?image=3d200117tx.jpg
3dmark locks up @ 255 (ddr510) heh
bf2 and source no crash :D
When is Newegg supposed to get more of these in?
Who knows....CE-6 supply is shoring up though.Quote:
Originally Posted by Ub3r-L33ch
Mushkin is getting some in Thursday.
I ordered mine yesterday, and they were out :(
But now I get free overnight, so....can't complain.
Will be glad to trade the Ballistix for these
we got a lot more coming in. so dont u worry.. just keep letting us know how it performs.
Duonger
I'm surprised they didn't run out sooner given that they're currently the only player in town atm.
Same as mine:(Quote:
Meaning i did the right thing ;)Quote:
Originally Posted by Phil The Greek
Yep.I am going to buy an opteron 146 on Monday just to see if there is something to do with the IMC but I don't think so.Quote:
Couldn't hit 280 at all 1:1. Was able to do 300x9 on a 180 memory divider with timings of 3-4-3-8. 2.8v too. Pretty bad. :/
:woot:Quote:
Originally Posted by Duonger
And since when is 280 bad? This stuff isn't UCCC...it's not meant to clock to 300MHz (although only one UCCC sample I've seen has), it's more meant for great clocks at 2.5-3-2 and 3-3-2.
I am at a wall currently with 260 3-3-2-8 2.86v. 1 Mhz above this on the FSB and lockup with 3D benching and games. I can run all day no problem at these settings in picture below.
My cpu limit is 3260Mhz 1.65v and I was hoping to get about 265 out of these sticks. Here is a screenie, any suggestions or comments on those settings???
Also can you set in BIOS the Tref (refresh rate) 200mhz 15.6us, Max Async Latency or Read Preamble? Or do you just have to set in Windows with A64 Tweaker.
http://img222.imageshack.us/img222/9...mall4bk.th.jpg
try takeing the tref down
Nope, tried lower tref settings and nothing. Still a wall at 260. :(Quote:
Originally Posted by sin0822
