wow, ur sandra cpu score is very weirdQuote:
Originally Posted by gecko79
I get that at 3.3G with my 4000+ SD :confused:
Im not only
dont understand
Im not only
dont understand
There is definately something wrong with that score. Here's my 3200+ Venice @ 3300 and somehow his is almost as fast???? :confused:Quote:
http://img215.echo.cx/img215/548/10x3309ye.jpg
http://xtremesystems.org/forums/atta...chmentid=31786
enteresting.. what is your cooling?
A64 Tweaker screenie or I call BS. :p:
Phase Change, but it shouldn't matter what cooling and what memory settings. This test only tests the cpu........Quote:
i have those CPU to test :
http://wowgame.free.fr/Divers/0517.jpg
for the moment :
BPEW -> 2900Mhz OCCT ok 1.696-1.712v
DPMW -> 2900Mhz OCCT (problably ok) 1.504v (same as other as i've tested)
EPAW -> test this WE juste boot 2800 1.396v
i'll keep EPAW
result soon :toast:
PS: all watercooled :D
I'll tell you right now - the reason why that EPAW is that good isn't because of it's stepping ;) Take a look at the cpu's again and you'll see why I say that.....Quote:
Originally Posted by overcrash86
Hmm, don't see anything :confused:Quote:
Originally Posted by s7e9h3n
+1Quote:
Originally Posted by HiJon89
i don't see :confused:
Here's a hint: Look at the serial #'s :p:
Ok, forget it...this game is going to take too long to play :D The epaw's batch code is 65, the others are in the 1000's :cool:
This is BS.
Are you referring to me?Quote:
Originally Posted by ReelMonza
You should have waited longer! I had some friends trying to figure it out.
i'll look the 3 other into my shop tomorrow to know what are their number...
You know, the only reason I posted so quickly was because I had seen another post not knowing what the answer was. I figured I'd save a couple of pages of wrong guesses so this thread could be easier to navigate, but somehow that post had disappeared while I was writing my response :confused: ???Quote:
Originally Posted by Ugly_Jim
Hmm a 3200 vs 3000's ?
But why should that offer such a big difference in volts/OC?
s7e9h3n you've always got great info! I've had 3 venice chips and the lower that numder is the better they seem to OC! :D :toast: :banana:
hmm interesting.. so it's not mainly the week then.. it's the serial now?
so lower number better ocing ?
here's mine
http://img88.echo.cx/img88/4519/hpim03335rl.th.jpg
sorry for before :D
Originally Posted by TEDY
thats a winchester, not a venice, => wrong thread ;)
Mines 0234 :) {{end of serial}}
Guess thats good then? :woot:
Nice one s7e...... :)
You and your affiliations at AMD :p: But good info, it was a rumour but now its confirmed :) Thanks!
Here is my 3200+ Venice's batch number...
Can do 2921MHz SP32M with air :D
0057
Man that's insane!!! Which vcore?Quote:
Originally Posted by Dani
