3200 Mhz stable on air default voltage maybe?Quote:
Originally Posted by HARDCORECLOCKER
*dreaming*
:p:
One problem though...my wallet isn´t that thick I can afford a pricey cpu.
*dreaming*
:p:
holy :banana: :banana: :banana: :banana: that is :banana4: :banana: :toast: :stick: :confused: :p: :) crazy
:toast: cheers buddy, keep 'er clockin'
It's kinda scary if you think about it. This 3800+ is able to, at the least, compete with today's FX55 at less than half the price. If the San Diegos' silicon is truly the pick of the litter, their benchmarks compared to the Venice will be what SLI is compared to PCIE (Well actually not that drastic, but it's the only thing I could think of :) )Quote:
:D Personally I expect the FX-57 to run 3,5GHz on single phase without any problems......, so we will see.Quote:
Originally Posted by s7e9h3n
:toast:
Okay now run some Prime95 goodness! :toast:
in cpu-z, you can hit f5 to save a bmp directly from the program instead of having to open photoshop/paint or whatever and pasting it. much easier imo :toast:
If only I could run my rig remotely from work :DQuote:
Originally Posted by WiCKeD
Didn't know that....I'll try that later on tonight. Thanks for the tip.Quote:
Originally Posted by ozzimark
:D O.K. - having an IQ only a bit above a banana myself so please tell again how it exactly work, open CPU-Z, hitting F5 and then ???Quote:
:toast:
It saves the .bmp in the same directory ya have cpu-z.Quote:
Named cpu.bmp if you have the cpu tab open.
What are you running server2003? It doesn't have remote management built in?Quote:
If you freeze the machine your screwed, but I saw this device a while back that will reboot your computer if it detects a system crash. So, as long as you stick with Clockgen and a64 tweaker, you can run tests from work...
http://www.thinkgeek.com/computing/accessories/678e/
And even without this device You could at leats run some tests that aren't too crazy, until you freeze the system...
good lord s7e9h3n , that is really spectacular! excellent work. When ya get home from work, doa bit of benching, but then get some sleep man. We're excited to see what this Venice can do, but you don't need to be killing yourself over it.
Again, thanks a lot. :up:
:D Ah, I see now, THX mate.Quote:
Originally Posted by Caper
:toast:
You should thank ozzimark, didn´t know about this before he mentioned it.Quote:
Pure luck that I noticed the screenshot was saved in the cpu-z directory, or is it so that I have an IQ above a banana...maybe like two?
:D
worked for me, thanks for the tip, btw anyway to save to jpg directly?Quote:
here's my screenie, if anyone wants sandra or w/e benchmarks just ask :p:
(can't use my a64 system since I'm waiting for replacement 3500 and VX)
http://www.xtremesystems.org/forums/...id=26769&stc=1
So let me get this straight, the following was done on air ???!!!!!
http://img164.exs.cx/img164/2226/patched9pb.jpg
:slobber:
Perkam
No. That one is playing in the cold.
nope. not yet at least. i would actually prefer .png because it's smaller and lossless :toast:Quote:
Originally Posted by S0nic
and conrad, how cold?
Check back a few pages. I think he's playing in this temperature range.
No, I believe this was the most on air:Quote:
Originally Posted by perkam
http://img57.exs.cx/img57/5921/10x2955oq.jpg
thanks, i somehow missed that while i was at class from 12-4 today. people post so fast :slobber:Quote:
Originally Posted by conrad.maranan
Now don't get me wrong - I'm into testing/benching my systems just as much as the next guy - but whoa, that is truly going a bit overboard. And besides, if you're gonna test the capabilities of a system, you're not pushing hard enough if you're not borderline BSOD :DQuote:
Originally Posted by J-Mag
Thanks conrad - I was busy contemplating remote-benching for a minute there - :DQuote:
Also, here's something odd to throw out to you guys. This cpu, for some reason, doesn't like it's default multiplier (12x) at these higher frequencies. It requires much more voltage at 12x to run any kind of bench. On the other hand, 11x seems to be much more of a "sweet spot" @ 3.0+Ghz for the chip. It seems to run more smooth and with less heat and vcore than both 12x and 10x.
is that TCCD you have? can you pull some max mem runs for use so we can see this new mem controller in action?
thanks
