Thank you sir! :up:Quote:
Originally Posted by dwwalker14335
btw: I just published a 23,333 (468/1181) with approved drivers
http://service.futuremark.com/compare?2k3=3830013
:toast:
:toast:
Thanks Man :banana:Quote:
Originally Posted by SPQQKY
Thanks for finding the scores, sorry i didn't post the links, they were already replaced by higher scores...Quote:
Afaik...I'm 1st person to break 18k in 03 with 6600GT's :toast:
But i have heard that if you put all yours services out in win xp that your score at benchmarks will come bigger. But here i get less score without the services.
Or is it best to don't turn off ALL services?
Some of the essential services are needed, but some are not when running a game. Turning off all services will turn of some necessary items. I just run mine all running. I found it does not make too much of a difference. But, if you are a few points away from the score you need, it can help you get that last 50 points.Quote:
Originally Posted by C_X
How many processes do you guys run?
Soz here are the clock speeds for that 18k run
1. 18,049 JasonHK, CHAINTECH 6600 GT @ 631/1340, 3200+ @ 2.7 GHz
It's the descrption because i saved then submitted later..so it doens't save the clocks.
Got it, thanks!Quote:
Originally Posted by Jasonhk
No doubt I'll be pushed off soon but in the meantime OC glory on 3dMark '05 at 11,268! :banana:
337x9 (9/10 divider) 3000+ 1.65v MachII
DFI NF4 SLI-DR
OCZ Platinum Rev.2 2.5-4-3-6 3v
Koolance Exos and blocks on cards
Nice clock on the 3000+. Result posted!Quote:
Originally Posted by gundamit
And, you have a one result buffer. And, looks like OPP is working on some SLI results.
Then I need more buffer!Quote:
11,417 on '05. :toast: Hoping I have a little more left on the core. I'll try again Saturday.
That'll do it! Should be safe a little while longer ;)
guess i left my run too late hehe but first proper run with non-71.24 drivers
3dmark05 SLI with 76.41 drivers
11,185 eva2000, 2x eVGA 6800 Ultra PCI-E SLI stock heatsink @ 453/1215, A64 3500+ 130nm@ 2806mhz | DFI NF4 SLI-D 310 bios
http://www.fileshosts.com/DFI/NF4_SL...5_11185_tn.jpg
Probably get a few more pts switching to 2x256MB BH-5 @270+mhz 2-2-2-6 heh
switched ram with 3dmark05 SLI with 76.41 drivers
11x306HTT = 2754
9:10 divider for ram @275mhz 2-2-2-6 1T
11,194 eva2000, 2x eVGA 6800 Ultra PCI-E SLI stock heatsink @ 453/1215, A64 3500+ 130nm@ 2754mhz | DFI NF4 SLI-D 310 bios
http://www.fileshosts.com/DFI/NF4_SL...5_11194_tn.jpg
Nice one guys all those scores are wicked :) respect
3dmark2003 changed from 76.41 to 76.10 drivers for
11x306HTT = 2754
24,182 eva2000, 2x eVGA 6800 Ultra PCI-E SLI stock heatsink @ 453/1215, A64 3500+ 130nm@ 2754mhz | DFI NF4 SLI-D 310 bios
strange
76.41 = 23,671
76.10 = 24,182
edit: update
11x306HTT = 2754
24,264 eva2000, 2x eVGA 6800 Ultra PCI-E SLI stock heatsink @ 454/1215, A64 3500+ 130nm@ 2755mhz | DFI NF4 SLI-D 310 bios
http://www.fileshosts.com/DFI/NF4_SL...5_24264_tn.jpg
No more core left according to Coolbits. But no sign of any artifacting at 453 limit. Trying Rivatuner and having better luck with the video memory. Swapped in my BH-5 - almost no change. So BH-5 at 250 = TCCD at 300 11,649 on '05 #20 on page 1 however briefly! :banana:
Every little bit counts. You keep sneaking up the list. Nice work on the GT's. Others have trouble getting their Ultra's to those clocks.Quote:
The bios edit for 1.4v is starting to looking tempting. Mixed results from what I've read, but may be worth a shot next week.
Okay final post for a while until I get more info on the bios edit. Had to push my processor because the cards are all tapped out. 11,665 on '05 Just enough to bump myself back onto page one. :)
The 1.4V BIOS edit helps a ton. I had a 6800 GT (AGP) where I did the mod, and it added 20 MHz for 465 on the core from a prior peak of 445. And, that was air cooled with a stock Ultra cooler (used one of from my Ultra card). So, a pretty significant gain for a simple BIOS tweak.
SLI 6600GT Gigabyte GV-NX66T128VP
df 500/1120@570/1250
3000+@
3D2005 : 7246
http://service.futuremark.com/compare?3dm05=715715
3D2003 : 16201
http://service.futuremark.com/compare?2k3=3840256
After a few hours of :brick: and :cussing: trying to figure out why my scores were taking a huge dump after the bios edit, I finally went back to the old bios. When I found they were still underperforming I initially thought I had damaged my cards. After a while I finally traced it to a installation/uninstallation issue with '05.Quote:
Finally after more than a few hours after I started the project I was able to run a clean test of '05 and was rewarded with a nice bump. 11,786. :woot:
EDIT: Update: 11,830 That's it. No more CPU or GPU to give. Time to game. :)
gundamit nice score there with nice clocks on your cards :)
Yeah. Now I just need to fight the urge to do the bios edit for 1.5v.Quote:
Originally Posted by eva2000
:D
