MSI K8N Neo2
2*256 pc 3500 Corsair Rev 1.1 BH5
Aircooling box
MSI K8N Neo2
Aircooling box
Thats the chip I just got last night....Quote:
Originally Posted by SupremeKoala
Still learning my way around the 64 platform, and have to use the stock amd hsf for now, not gonna bother hooking up WC solution, going str8 to prommy when the kit gets here.
Hey guys, i got the 3000 winnie and In the bios I'm running the volts @ 1.65, but cpu-z shows 1.55. I heard about winnies undervolting, but can this just be a motherboard issue reporting it wrong? Im on the K8N neo 2 on the 1.41 beta bios.
nice, what week is your chip??Quote:
Originally Posted by Sauron_Vie
Its a known fact for the mobo to undervolt by 0.1v ... nothing to be alarmed abt, just the way it is :D
well the thing is, i have the 3500 939 (.13) and it doesnt undervolt it. So I'm not sure. How can I really find out by testing or by Msi support that its undervolting?Quote:
Originally Posted by geosin
I honestly find no difference when running 285fsb 1:1 with 2.5/4/4/8 as compared to running 220fsb with 2-2-2-5. In fact, running with lower timings resulted in better performance. The only benchmark to benefit from the high FSB 1:1 is sandra mem bandwidth.
Can anyone provide info to prove that running 285fsb 1:1 with loose timings is better than running a lowr fsb with tightest 2-2-2-5 timings??
ADA3200DIK4BI
CBBFD 0433SPMW
1058936H40510
MSI K8N NEO4 Ultra
Apacer Real500 TCCD 256x2 2.7v
Aircooling Box
http://home.pchome.com.tw/club/qk4723/3200/2700.jpg
With a NW/Claw, it will give the correct voltage when set in the BIOS, but with a Winchester it will give .1 below what you set it to.Quote:
Originally Posted by NonProphets
stock for 130nm 1.5v
stock for 90nm 1.4v
jjcom
@stelleg151: 0440 MPMW
Originally Posted by qk4722
I still can't believe my CPU of the same stepping is doing 2500MHz max Prime stable... :brick: :brick: :brick:
If you are like 'oh my god my winnie fails at prime95' check this out ...
http://xtremesystems.org/forums/show...d=1#post622796
here's what i just posted in "Athlon A64 overclock record" thread.... i'm kind of excited so i'll post it here to in case not everyone checks that other thread out:
here's my GO at A64 S939 - 270x10=2700MHz @ 1.63v REAL, DDR540 6-2-2 cas2, OCZ DDR Booster 3.7v
MSI K8N Neo2 Platinum - Q47353.1 0440A2 S Taiwan
A64 3200+ 90nm "Winchester" - CBBFD 0441UPCW
Thermalright XP-90 w/ YTech 120mm
CLICK for Full Size Screenshot - 2048x1536 384KB
http://www.xtremesystems.org/forums/...chmentid=20513
This is max SuperPi 32M and 3dMark2001 stable.... 265x10 is my 24/7 usage so far :)
has somebody A new 3500+ winchester with KW440 or higher?
Is Good?
Week
ADA3200DIK4BI
CBBFD 0437RPCW
1122547 J40461
Msi N8N Neo2 NB= 047353.1 0440A2 STAIWAN
Thnks :D
Ur CPU is not very good...I think so ( no rule is right 4 all ).. Best choice same to be 0441 n 0433..Quote:
Originally Posted by Mickey Mouse
Ur Mobo is good... same same me :D
Right now I'm trying to find my max cpu clock. I think I found it. Now it's time to get my ram sweetspot matched with the cpu.........
Week 41 3200+ oem from monarch /1.6vcore
watercooled
2700 is prime stable / 2750 is 3d stable
this is in single channel 1x512 VX gold at 225mhz 2-2-2-10 1T
2m run in superpi
neo2 1.36 bios
http://xtremesystems.org/forums/atta...id=20547&stc=1
so guys do you think it is a good bet to just stay with the 3200 winnie and hope for the best or, should i spend the extra cash to get the 3500 winnie?
....................................3500+ imo
thx trans:Dam
It's just that you get more multi options with the 3500+, Also you need to note that right now AMD has no better 90nm cpu than the 3500+....... What this means is that when AMD speed-bins the winchester cpu's, the fastest chips will be put in the 3500+ speed bin. Normally you would have the 3800+ and FX to compete with, but since they are 130nm right now, they are excluded from the speed bin, putting the best 90nm into the 3500+. I would probably wait until after January for latest stepping.Quote:
Originally Posted by aCidbAbY
trans am. you got lucky. I just got my 3200 week 41 oem from monarch and it tops out at 2.5... your a lucky guy... that is the cpu that i was hoping to get.. lol.. I wonder what I would have gotten if i waited and purchased the 3500...
LOL! here are the screens with the el4200 platinum 1:1!!! 31s superpi is awesome! Tonight must be my lucky night! phase change on the way! hurry up Reggie!!! oh, AND THIS IS NO BULLCRAP post high screens and run! THis is 100% Prime95 torturetest Blend stable!!!!!
http://xtremesystems.org/forums/atta...id=20567&stc=1
wtg trans am! congrats.
This is odd, I expected your 1m run to be lower than 31s. We have the same clockspeed, but your ram is going much faster than mine, but we both have 31s in superpi. Is this 2T?Quote:
